There is a button on the television, You check at the lower end of the television or on the side of the television. There You have the menu button, then You will see the channel and volume button, those are to navigate through the main menu after pressing the menu button.
When You press the menu button, You will see the main menu page, then You navigate with either the volume buttons or the channel button to channel settings, then You go to search, then You select either the auto search or the manual search, then You search and save Your channel using the buttons as earlier used.
Hope this helped.
Thank You for using fixYa
