Heating & Cooling Logo
Posted on Jun 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a new house and wanted to know how many square feet this unit will support. My house is 2,163 square foot single story ranch in Phoenix, AZ. The model is 24ABB360A320.
Anonymous
Level 3:
  • Master 455 Answers
  • Posted on Jun 10, 2011
Anonymous
Master
Level 3:
Answers
455
Questions
0
Helped
143212
Points
1102
HI YOu have a 5 ton unit =60,000 btu=12000 does 500 sqft=2,500 for you no problem.good luck & thanks
House gets hot in summer, intolerable,split ranch,lr cathedral ceiling,house southern exposure
That's a pretty wide open question. Help us help you. Do you have a.c., what size, square feet, is it working at all, temp splits, clean filters, good air movement, clean coils??????
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Rates,Proportions and Percents
that is one huge bathroom you must have the footage wrong. Divide the $762.50 by the cost of the carpet per square foot to get the cost .
How many square meters in 90,000 linear feet of 41.3" wide material?
First, we need to determine the number of square units in the Imperial system. We can choose to do the calculation in feet or inches.
Let's do it in inches first. There are 12" in a foot, so we multiply 90,000 by 12 to get 1,080,000 linear inches. Multiplying this by 41.3", we get 44,604,000 square inches. We can convert this to square feet by dividing the number of square feet by the square inches in a square foot. Since a square foot is one foot by one foot, or 12 inches by 12 inches, there are 144 square inches in a square foot. Dividing our previous answer by 144 will give us 309,750 square feet.
Converting to square metres. An inch is defined as 2.54 centimetres ("cm"). Thus, there are 2.54cm x 2.54cm in a square inch or 6.4516cm^2 in a square inch.
Using the 44,604,000 square inches we got above, and multiplying this by 6.4516, we get 287,767,166.4 square cm. There are 100 cm in a metre, so there are 100cm x 100cm in a square metre. So there are 10,000 square centimetres in a square metre. I get 28,776.7 square metres.
There are 3.280839895 feet in a metre. So there are 3.280839895 x 3.280839895, or 10.76391042 square feet in a square metre. Taking 309,750 square feet and dividing by the 10.76391042 we get 28,776.7 square metres.
Good luck.
Paul
Turn 675 squared feet into room dimentions
You can devide it up how you want. 675 squar feet is like having 675 one foot by one foot squars so a room that is 10 foot in one direction and 10 foot in another is 100 square feet so 6 of those would be 600 square feet and say a room that was 7.5 foot by 10 foot would be 75 foot
What is 9600 cubic ft converted to square ft?
Cubic foot is a unit of volume. Square foot is a unit of area. There is no direct conversion between them.
A 9600 cubic foot room with a ten-foot high ceiling is 960 square feet. If the roof is eight feet high, the area is 1200 square feet. If the roof is 12 feet high, the area is 800 square feet.
Convert 2,000 cubic ft to sq ft
Cubic foot is a unit of volume. Square foot is a unit of area. There is no conversion.
Let's say you have 2000 cubic feet of mulch. That can cover a 2000 square foot yard one foot deep. It can also cover a one square foot flowerbed 2000 feet deep.
How many feet is 350 linear feet?
Linear feet are a measure of length (no different from feet); square feet measure area. You cannot simply convert between measures of different kinds of quantities;the connection between them will be specific to a particular problem.A practical example in which this question can arise is in buying countertops for a kitchen. Some materials are sold by the square foot; others (basically those that are extruded, so they come in standard widths) are sold by the linear foot. In order to compare the two, you need to compute the area and wall length for the countertop you want.You can't convert between the two. All you have to do is to make the appropriate measurements so you can calculate the price of each item.The terms used in the lumber industry are a bit confusing.There are two terms that I think you might be mixing up.A LINEAR FOOT is simply the length of a board. If you want to know the area or volume of the board,you need additional information. For instance, 6 linear feet of 1-by-12 has an area of 6 square feet (12 inches = 1 foot, times 6 feet), and it's 1 inch thick, so the volume is 1/2 cubic foot (6 square feet times 1/12 foot). But 6 linear feet of a 1-by-6 board would have half the area and half the volume.A BOARD FOOT is equivalent to one square foot of a 1-inch-thick board. In other words, it is a square-foot-inch (ft^2-in), or 1/12 cubic foot.Linear feet are used for the pricing of a single size such as two-by-fours. Board feet are used for larger lumber that you are more likely to want to compare directly with different size boards .To sum up, neither a linear foot nor a board foot can be converted directly to square feet. A linear foot is a linear (length) measure, and a board foot is a volume measure. You need to know your particular board to do anything more, such as find the area.an example with an" L" shaped countertop will betwo rectangles are 24 by 80 inches and 24 by 36 inches. Thus the area is: 24 * 80 + 24 * 36 = 24 * (80 + 36) = 24 * 116= 2784 sq. in.To get it in square feet, divide by 144:
2784 / 144 = 19.33 sq. ft.The linear measure of this countertop would be 60 + 80 = 140 inches = 140/12 feet = 11.67 feet
Cubic feet calculator
Cubic foot is a unit of volume. Square inch is a unit of area. There is no direct conversion between them.
An area of 144 square inches and a foot high would be one cubic foot. So would an area of one square inch and 144 feet high.
Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
Brand new unit have 3 ton inside and out but unit runs all day and will not hold temp i run my ac on 76 but as the day get hot the temp inside will not hold at 76 ARS says they dont know whats wrong but...
call them back something is wrong if it is that new it is likely under charged. how big is your house square feet and what part of the country down south 400 square feet per ton if your house is more than 1250 square feet the unit is under sized since it is new did some body do a load calculation on the house if ya bought from a reputable dealer and you are getting no help call the manufacture. or the better business in your area good luck. Tom
Top Heating & Cooling Experts
Paul Carew
john h
