Bosch Classixx WVF 240S Front Load Washer / Dryer Logo
Julian Sykes Posted on Jun 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
How-2-Repair.com
Level 3:
  • Bosch Master 746 Answers
  • Posted on Jul 19, 2013
How-2-Repair.com
Bosch Master
Level 3:
Answers
746
Questions
0
Helped
592424
Points
1880
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
sheakhly
Level 1:
Habit-Forming:
New Friend:
  • Contributor 34 Answers
  • Posted on Jun 10, 2011
 sheakhly
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
34
Questions
0
Helped
7580
Points
62
Maybe the heater was damaged or themostat
Bosch classixx washing machine is not heating the water
Have you interchanged the hot and the cold water valve? Check your installation. If the installation is correct, the hot water valve might be the problem. You probably need to replace it with a new one.
http://www.washingmachineadvisor.com
12helpful
Got the Bosch Classixx 6 1400 Expresswashing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks!
3answers
I have the same problem - Did you mange to sort it out?
12helpful
Got the Bosch Classixx 6 Express 1400 washing machine cant
1helpful
2answers
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
2helpful
2answers
Bosch Excell washing machine programme fault
Bosch classixx 6 1200 washer
Problem will be ... machine will use your hot water during the rinse cycles! So, No.
Problems with washing machine cycles
does it heat up? if not the element has gone and needs replacing. try it out on a cold 30 wash to see if it goes through if so element probs.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
