If you use a headset frequently, it's important to change the ear
cushion periodically. Ear cushions absorb a lot of sweat, dirt and
makeup and can breed bacteria if not cleaned or replaced as necessary.
This can lead to bacterial ear infections in extreme cases. Repeated and
frequent use can also cause foam ear cushion to deteriorate and break
into pieces over time. portable mp3 player
The ear padding is attached to and held in place by a plastic ring that fits into the speaker mount. Gently pull the ear padding outward so you can see the ring, then slip a flathead screwdriver or other object in (just a bit, you don't want to poke the speaker inside). Gently pry up , sliding your pry-bar along, and the pad should pop out quite easily.
Amazon has genuine replacement pads for HDR140 and RS140.
