The last spin cycle does not drain completely. When the washer (at the 11 min. mark) tries to go into the spin mode you get an unbalanced load code. There is some water left in the tub. Removing the water and machine completes spin cycle completely
Sounds like you washer is trying to spin out and becoming unbalanced and cutting off.. Move timer to spin and see if water spins out. If so try running a load and say with it so if it becomes unbalanced you can arrange clothes before returning timer runs out.
Recently, the "LF" code has started to display and the soak cycle will not complete unless I ... Kenmore Elite Top Load Washer - Unbalanced Loads During Spin Cycly ... Would a bad outer tub literally cause the basket to become unbalanced?
? 1:21
https://www.youtube.com/watch?v=cVZIGhULzg0
Jan 17, 2014 - Uploaded by Carpe Diem
How to fix unbalanced high efficiency top load washer. ... I am having a MAJOR problem with unbalanced ...
LE code mean suds have built up. Using non he (High Efficiency) detergent or too much detergent will cause this error most front loaders use he detergent only there is a he swirl on the container
Let your washer sit idle or 45 minutes.Unplg washer as well
Plug in and turn on as left spin speed select no spin press Start/pause to start a drain only cycle. When cycle is complete remove load. Start a rinse•spin cycle to clean out residue.
If the sud were too much you may have to repeat
Good deal your machine is a Series 11. “”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.”” I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected? Are there any error codes to the LED display like dC or uC? If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code? Does the wash tub bang around in Spin Only cycle with the wet clothes load? Standing by for some feedback and I will try to help. Here is the Service Manual and parts look up.Can you let me know if you want to try to DIY the fix? FAV6800A/FAV9800A Service Manual for reference.Sears Parts Direct for reference. Rich
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
If it’s an FAV6800A I think you may have a clutch malfunction with your machine.To verify if the clutch has malfunctioned we need to perform a quick check.Please visit this link and review my post of Solution #1 posted on Jan 30, 2009. Steps 1 & 2 should get you started and give us some troubleshooting direction. Please post back with your results or if you have any questions.
being un-level could certainly cause it im currently working on this problem for another customer on this site while i haven't had hands on with this model yet i just finished reading the service manuel on it its kind of an amazing concept in washers if either one of you are on line reply to this message hold my rating for now as i need to ask some questions
