Question about Razor E100 Electric Scooter
Is 9.5 volts out of the battery to low to run even a little?
    New Friend:
  • 11 Answers
I'm afraid yes the voltage is far too low to run a Razor E100, the scooter needs the full 24v.
Posted on Jul 05, 2011
SOURCE:
Gauges, door locks, radio go crazy.weird noise from dash. battery tests at little over 12 volts. HELP
If the vehicle is running an your only seeing a little over 12 volts you have a alternator or wiring problem . You should see 13.1 to 14.1 volts with the vehicle running an that could cause your strange problems . low voltage !
Oct 12, 2015 | 2001 Oldsmobile Silhouette
Any one savvy with cars please help me. I have a 1996 ford taurus gl it was running fine until today. I thought it was low on gas so I added more along with motor oil because mine was low now it won't...
I would say that the battery is flat or old and wont hold a charge, or the terminals are dirty. probe the terminals with a volt meter around 12 volts ok ,if little or no voltage probe battery posts 12 volts ok , if voltage ok now terminals dirty, if no voltage battery flat or dead.
Oct 16, 2014 | Cars & Trucks
Honda goldwing gl 1800 slow turnover battery reading 11.97 volts
Could be either a bad battery or the alternator not charging causing a low battery. Volt meter on good battery should read at 12 or a little more just sitting with motor off and about 13 to 14.5 volts while bike running at the proper rpms.
Jun 15, 2014 | Honda Motorcycles
When I turn the key it only clicks, starter does not engage
It's either a bad battery (low on charge) or a loose ground wire. If you are SURE that the battery has 12 volts (yes, even a low battery will run your lights, radio, door ajar chime, etc., but won't have enough to start the car). If the battery is fully charged and your volt meter shows 14.4 volts (fully charged battery reading), then it's a ground wire. There are two locations. The negative battery cable itself on the battery, and the location on the frame or engine where the cable connects to.If these are ok, check the positive cable connection on the starter.
May 11, 2010 | 1994 Lincoln Town Car
Batteries
I think you will find that one 9 volt battery would not last any time at all. the 6 AAs have a big capacity and that's why they use them, a little 9v battery is intended for low power equipment.
I see it is supplied with a 12v AC adaptor, if you connect a 12V battery via the adaptor socket you may get a longer run time if its a rechargable battery even better.
Jan 22, 2010 | Meade NIghtView NIght Vision Monocular
My 2000 mercury Mystique wont start when i turn the key in the ignition is just clicks what could it be alternator starter or battery?
first check battery voltage. should be 12 volts or a little over. IF the battery is low then charge battery and then load test battery. If you remove you battery and take it to local parts store most will check for you. if battery load test good but was low on voltage then I would check to see that alternator is charging while engine is running. should be charging aprox 13.9 volts. if battery had full voltage and load tested good then most likely the starter is bad.
Jan 16, 2010 | 2000 Mercury Mystique
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Bike won't start, battery bulged
It is probably the voltage regulator which is allowing an electrical surge to blow out the low beam head light bulb.
Jul 13, 2009 | 2001 Yamaha V Star 1100 Classic
20KW Guardian Generac does not produce 12 volts to run engine
The problem is that the printed circuit board inside the generator draws a little current from the battery even when the generator is not running. Over the course of a few days this can make the battery weak enough to be unable to get recharged by the built in running charger which results in not enough power to run the electronic governor on the generator. Usually the spark plugs will work even with a fairly low battery.
Most of the Generac generators come with a built in trickle charger that runs off of the transfer switch load terminals. If your built in charger isn't doing the job it's either broken or you have the wrong sort of battery installed in the generator.
Regards,
Carl
Jan 11, 2009 | Electrical Supplies
Wont start
Start vehicle up and take vehicle to an AUTO-ZONE they will check the entire charging system for FREE. This could BAD battery or a BAD alternator or even maybe both. So let not guess or if you have a volt meter at home with vehicle running voltage at battery polls should be at least 14 volts and without vehicle is running battery should be at least 12volts how ever with voltmeter you can't LOAD-TEST battery or alternator, But if alternator is less than 14volts it may be charging too low and if batter is less than 12 after it was fully charged or after car had been running for at least 15 minutes> BATTERY IS BAD> Good Luck and contact if you need more help. Thanks for using FIX YA
Jan 08, 2009 | 2001 Daewoo Lanos
Razor E100 Electric Scooter Logo
107 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
Are you a Razor Toy Expert? Answer questions, earn points and help others
