We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
The sensing light is the part of the machine that senses moisture inside the dryer itself. If it senses moisture the machine will continue to run until its satisfied that the clothes are dry
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
The "Sd" or Suds Detected error means that you used too much detergent.
Reduce the amount of detergent that you use, and properly measure it.
When you receive the "F50" code, it means that the motor position sensor does not sense
that the basket is moving. Remove any remaining packing material from
the tub.
it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, determine cause of friction. ➔ If basket turns freely, see TEST #3, Page 10. the above link is for code 51, very similar. the quite above is from the PDF manual. I just solved this problem on my machine. turned out it was clothing between the 2 baskets. Others have had bad control boards, or bad sensors
