Did you tried connecting the oven power cord to any other separate power outlet.Connect oven to the outlet, when only oven is connected and no other appliance is connected.-------
The power is getting cut for a second .It can be issue with wall electric outlet.Or the oven is not getting exact power/voltage.Or the over power cord is getting short internally.Or the issue with oven power control board timer.Its cutting off every few seconds and this resets the time.--- If this is the case then board is weak and it has to be replaced.-----
First try check in other separate power outlet.If that is not helping then get the over voltage and power outlet voltage checked by the tech.If both checked out ok, then get the over power cord checked by meter.If meter shows drop in voltage, then there is cut in between the over power cord wire.------ But if all power cord wires, the electric wall outlet, the voltage, everything checked ok, then its timer control board issue.It has to be replaced.------------
You can get
required parts from online sites like: --- www.repairclinic.com
or from searspartsdirect online site. -----------------
This should
help.Thanks.Helpmech.
Here is a tip that will help you
The oven hookup is exactly the same...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
