Archos AV700 Digital Media Player Logo
Posted on Jun 09, 2011
When i turn my av700 on it says unable to read data from hard drive
2answers
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Lost Data becoz formating , where i can get it?
connect it to computer and try to recover it using this software: http://www.recuva.com/
remember selecting right device..
it may take hours to search the drive for deleted files..
if this does not work mail me on [email protected] and i start talking about some more advanced recovering softwares and such ..
My archos av700 does not charge
The problem turned out to be the charger, problem now solved, thank you
Western Digital WD 1200VE; 120 GB external hard drive unable to boot
You need to send it to a data recovery house like Drive Savers. The prices range from 500 to 3000 USD for data recovery and they can't guarantee 100 percent success. The platters need to be removed in a clean room and placed in a unit to read the data. They then copy the data to another drive or to optical disks. Unfortunately when the drive hit the floor the drive sustained physical damage hence not starting up.
Sorry to be the bearer of bad news.
Cheers.
Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Archos av700
is your usb lead broke, or maybe your computer is not picking it up, try opening my computer and see if you can find the hard drive, then just open it up and you will find the folders, let me know if this is any help
Archos av 700- Im having a problem with mine it keep coming up with can't read from hard drive error.
It only contains a laptop hard drive, so buy a new one remove all screws from either side of your av700 and replace it, dont worry cause once you open your av700 the hard drive is really simple to swap,then fire it up and format the drive you can download upgraded software from www.archos.com
Reformatting
That is the reason why you got IO error! that means your av700 hd may be in need to be changed.
Best thing to do is trying format again, if you cannot format again from av700 you need to remove AV700 drive and change it.
If this had been helpful o not forget to accept my solution in the pay for question, we are not rewarded for free questions solutions.
If you have more queries ask me
2answers
Archos AV700 I/O Error
Offhand, I would suspect that the remaining files were somehow corrupted. Is it possible for you to verify those files using the external HD and a PC?
Either that or the format of the Archos AV700 was not that "clean" and would require a redo.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
