SOURCE: JBL MR 17
I fixed the problem !!!!!!! All I did was, unpluged the 2 remotes , and the head unit worked fine. Next, I plugged on of the remotes back in. And it worked fine, Next, I plugged the swim grid remote back in, and everything went bad. So.... The swim grid remote is shot. I went on ebay and found a company that sells new ones. I think it was around $90.00. Had it shipped out, and installed it. It works perfect !!!! everything is working fine. !!
SOURCE: I have a JBL MR
if it has aux input rca's, then go to an electronics or car audio shop and buy a "stereo rca to 3.5mm headphone jack adapter cable" This will then plug into the headphone jack on the ipod.
Removal & Installation-of dashboard which includes removing radio.
CAUTION
Many BMW models covered by this manual are equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, properly disable the SRS.
The instrument panel removal is complex and requires disconnecting many components. Make sure to label and organize the components as they are disconnected, disassembled or removed.
3 Series Models
