Adobe PageMaker 7.0 Classroom in a Book (201756250) Logo
Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do insert page numbers on page maker automatically?
Anonymous
Level 2:
Novelist:
  • Expert 132 Answers
  • Posted on Aug 10, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
132
Questions
0
Helped
66740
Points
312
To have Adobe® PageMaker® automatically number your pages, if the template isn't used, place a page number marker on the Master page of the document.
  • Go to the Master Pages by clicking on the page icons with the L and R on them at the bottom left corner of the screen.
  • Using the Text tool, draw a text block in the general area for the page numbers.
  • On the Mac, press Command+Option+P or in Windows, Ctrl+Alt+P.
  • Depending on the page you are on, the page marker will show up in the text block, LM on the left page, RM on the right page.
Auto page Number
  • This text can be formatted like any other text on your pages.
  • Select the Pointer tool and move the copy block into the correct position.
  • Click on a page icon to go to a page in your file and the actual page number will appear.
  • If the page icons do not have the correct page numbers on them, go to the File menu, select Document Setup and change the Starting page # field to the correct starting page number.
Another solution
Adding Page Numbers in PageMaker 7 Page numbers add shine and organization to any publication. In Adobe PageMaker 7, page numbers are quite simple to include, but function is difficult to find first time. After activated, page numbers show throughout selected project.
Instructions
Step 1
Start project in PageMaker 7.
Step 2
Choose text function from toolbox. It appears as T.
Step 3
Click L/R function. It is placed under ruler.
Step 4
Click master page where page numbers placed and push "Ctrl+Alt+P." Page number must show.
How can chapter titles be inserted into an existing document in Microsoft Word 2010?
Insert The Chapter Number And Title In A Header Or Footer
First divided your document into sections in order to insert chapter numbers and titles into headers and footers.
1. If you haven't done so already, insert a section break where you want to start a new section that contains a different chapter.
a. Click where you want to insert a section break.
b. On the Insert menu, click Break.
c. Under Section break types, click the option that describes where you want the new section to begin.
Note: If you have already inserted a page break to cause the chapter to start on a new page, delete the page break and replace it with a section break that starts on a new page.
2. Apply a built-in heading style to the chapter number and chapter title by clicking a heading style in the Style box on the Formatting toolbar.
Or to have Microsoft Word automatically number headings, use the Bullets and Numbering dialog box to format chapter headings.
a. On the Format menu, click Bullets and Numbering, and then click the Outline Numbered tab.
b. Click a chapter-numbering style (one that includes the text "Heading 1" or "Heading 2," and so on), and then click OK.
c. Type the text you want for the numbered heading, and then press ENTER.
d. To add the next numbered heading, go to the next chapter heading, click the arrow next to the Style box on the Formatting toolbar, and then select the heading style you specified in step 2.
1. In the first chapter, on the View menu, click Header and Footer.
2. If necessary, move the insertion point to the header or footer you want to change.
3. Insert the chapter number or title.
a. On the Insert menu, point to Reference, and then click Cross-reference.
b. In the Reference type box, click Heading.
c. In the For which heading box, click the heading that contains the chapter number and title.
d. In the Insert reference to box, select what you want to insert in the header or footer. For example,
• Click Heading number to insert the chapter number.
• Click Heading text to insert the chapter heading.
e. Click Insert, and then click Close.
4. Click Show Next Button image to move to the header or footer of the next chapter.
5. If the header or footer in this chapter matches the one you just created, click Link to Previous Button image on the Header and Footer toolbar to break the connection between the header or footer in the current chapter and the previous chapter.
6. If there's already text in the header or footer that you don't want, delete the text before inserting the chapter number and title.
7. Repeat step 5 to insert the chapter number or title of the current chapter.
8. For each chapter in the document, repeat steps 5 through 9.
5helpful
DELONGHI PERFECTA SAYS INSERT GROUNDS CONTAINER WHEN IT'S ALREADY INSERTED
Just had the same problem after washing my ESAM5500.
Seems that some water hot on the switch that is triggered when grounds container is inserted.
My solution was removing the bottom panel (5 screws if I remember correctly) and disconnect the green wire from the switch (there are three wires - green, ping and blue). When the green wire is disconnected, coffee maker thinks that grouns container is inserted all the time - even if it is removed.
1helpful
Where can I down load a manual for the Black and Decker all in one bread maker
What is the model number of Black and Decker bread maker that you have? Many Black and Decker home appliance manuals are available here: http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4 . It's a long list.
The direct link to the B6000C, All-in-One Automatic BREAD MAKER, manual is here: http://useandcaremanuals.com/pdf/B6000CNEWUC.pdf .
The B2250 bread maker Quick Start Guide is available from http://www.blackanddeckerappliances.com/p-61-all-in-one-bread-maker.aspx . Scroll down the page. The full manual is here: http://useandcaremanuals.com/pdf/B220,B2250984.pdf .
The B2300 Horizontal bread maker Quick Start Guide is on this page: http://www.blackanddeckerappliances.com/p-62-all-in-one-horizontal-deluxe-bread-maker.aspx . The manual is here: http://useandcaremanuals.com/pdf/B2300986.pdf .
I hope this helps.
2helpful
Is there a way to determine the number of pages an Alps MD-1000 has printed, like a mileage gauge on a car.
Yes. It's very easy. Turn the printer off, unplug it, and disconnect the printer cable. Insert two sheets of paper, and make sure the paper feed is set to automatic. You need to have a black cartridge loaded into the 1st slot.
Plug in the printer and wait for the lights to turn off. Press and hold the power button at the same time press and hold the "ready/Insert" button. Release the power button, but keep holding the "ready/Insert" button for at least 4 seconds. After 4 seconds, release the "ready/Insert" button and quickly press it again. The printer will start the selftest.
For the 1300, the number of bands printed will be on page two. On the 1st page, there will be a black bar on the bottom of the page. It should be a solid black bar with no lines - this is the test for bad elements on the print head.
1helpful
How do I insert page numbers onto typed documents?
if you are in word double click up in the first inch of the document and then a menu should pop up and you have the option to add page numbers that go on automatically
I put page 1 on my page 4 and I did it, but there is no number on rest of my document; pages 2,3,3... are blank
I'll assume you mean MS Word and not an computer motherboard.
Page numbers are done by Insert command, Then Page Numbes. Specify the page location (left, Center, Right) in the pop-up window and you are done.Each page will then have the number at the bottom automatically.
I need a water valve for a Monogram zd115 Ice maker. Where should I buy one. and what about a part number??
If you have the model number of the machine, or the old part in hand, you should be able to get your part at any appliance parts supply house (look in the yellow pages). It is better IMHO to take the part with you to the store.
Best regards, --W/D-- please feel free to rate this solution - thanx!
1helpful
GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
4 Press {DIGITAL SP-PHONE}.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
number.
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
pressed.
To stop transmission
Press {STOP}.
39helpful
4answers
White-westinghouse automatic bread maker WWTR444A
Here is a quick pdf scan of the manual for a White-Westinghouse Model WWTR444A brad machine.
I didn't take great care in tweaking the scan. Some pages may have the edge cropped but all pertinent information should be discernible.
ENJOY
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
