Question about Nostalgia Electrics Helman Group KPM-508 Popcorn Maker
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
    New Friend:
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Posted on Jun 19, 2011
SOURCE:
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
Will not heat up and pop
Your power cord I would follow into the machine and hunt for a broken wire or a blown fuse possibly. Most pop corn makers are just about like a coffee pot. They have a klixon to control the temp and a couple of bullet fuses in line to prevent over heating. All of which is loacted on the base of the kettle. I wish I could be there to help ya get that popcorn popper working. Feetball season is nearly upon us.
Contact the makers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 05, 2012 | Nostalgia Electrics KPM-508 Popcorn Maker
Ineed a manual for a KPM-508
The Manual for the Nostalgia Vintage Collection Kettle Popcorn Maker may be downloaded from the following link:
http://nostalgiaelectrics.com/manuals/kpm-508.pdf
May 01, 2012 | Nostalgia Electrics OFP501 Old-Fashioned...
I need a new door for my popcorn maker its the large kettle popcorn maker kpm-508
The suer Manual for your Nostalgia kettle popcorn maker KPM-508 can be found here:
Have not seen any supplier carry replacement parts for the Nostalgia products. Suggets you contact Nostalgia through their Cusomer Service:
http://nostalgiaelectrics.com/default.asp?a=service&itemNumber=kpm-508&itemProduct=
Mar 13, 2011 | Nostalgia Electrics OFP501 Old-Fashioned...
I purchase this popcorn model number ofp901 i have no instructions it looks like the kpm508 and just need to know how much oil and popcorn
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a HOT AIR popper; oil SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
Mar 09, 2011 | Nostalgia Electrics KPM-508 Popcorn Maker
The glass door of our popper cracked during popping - is it possible to get a replacement door???
It may be less expensive to contact a local glass supplier and inquire what TEMPERED glass would cost.
Have exact measurements and thickness when contacting them.
Apr 26, 2010 | Bond Helman KPM-508 Popcorn Maker
Need procedure for using nostalgia electrics kpm-508
Here is a link to Nostalgia Electrics..Fill in their form and you can go from there. Here is the link...
http://nostalgiaelectrics.com/default.asp?a=service copy and paste it into your browser or try to click on it..Hope this helps you..Wayne
Mar 14, 2010 | Nostalgia Electrics KPM-508 Popcorn Maker
NEED USER GUIDE DIRECTIONS FOR THE NOSTALGIA ELECTRONICS MODEL #kpm-508
Hi there!
This should be it -
Clicky here
Please rate as Fixya! if it hits the mark.. Thanks.
Jun 19, 2008 | Nostalgia Electrics KPM-508 Popcorn Maker
Download nostalgia popcorn kmp508 instruction manual
Hi there!
Click here to download the manual
Thanks.
Please take a moment to rate as Fixya! if it hits the mark Thanks.
Jun 14, 2008 | Nostalgia Electrics KPM-508 Popcorn Maker
Nostalgia Electrics Helman Group KPM-508 Popcorn Maker Logo
372 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Anthony Ward
Anthony Ward
Sheldon Dedek
Gil Shultz
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
