Well you were told wrong site need to notify dealer with all information since radio is not the same one that came with vehicle also need to have proof of owner ship
The seller is cheating you. We do not have these codes. The codes are used to deter theft and resale, and you have become a victim, sorry.
SOURCE: Audi Concert problem
you must check wiring cable of left speaker-reconnect antenna cable and check if it is firmly connected and apply contact cleaner over faders.
SOURCE: 1999 audi A6 need radio code please
DO YOU HAVE THE ORIGINAL RADIO MANUAL THAT CAME WITH THE VEHICLE? THE CODE IS PRINTED ON THE CARD IN THE RADIO MANUAL. THAT PAGE ALSO GIVES THE INSTRUCTIONS TO GET RADIO OUT OF "SAFE" MODE.
YOU NEED TO HOLD DOWN THE BUTTONS DESCRIBED IN MANUAL TO GET THE RADIO DISPLAY IN THE CODE ENTRY MODE.
SOURCE: Audi A4 (2002) concert CD/Radio - all LED flashing radomly
Pulled out unit and found 5p inside - off to the professionals to be repaired!
http://www.ibiblio.org/tkan/audi/radios/radios.html
This link will help with the procedure, but you have to have the 4 digit code.
SOURCE: Safe mode in Audi Symphony radio
hold rbds and pscan till you see numbers then use the radio memory buttons to control the number you want to put in after the numbers are put in hold rbds pscan again till u see it says safe and radio works.
