Hi ferrojennife,
The E1 you are seeing means Water
Level in Drum lowering, this means there is a leak on one of the pipes.
More likely it is the Circulation Pump, which is responsible for
pushing the water to the Spray arms.
It will have to be replaced,
as it is a common spare that has to be replaced on L.G Dishwashers
(lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually
is about 20%-25% the price of a new Dishwasher. The Circulation pump is
fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending
which one is in stock)
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote for it
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
