Yukon SightMark SM650 Rangefinder Logo
Posted on Jun 09, 2011
My yukon sightmark sm650 rangefinder laser is not working.The golf shop sold me a "Parview LS650" after looking around the internet, it looks exactly like the sm650. To my question....the laser was found loose from the mount and was not working,,,,,,where can I get it fixed?How much to replace the lazer?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
293
Points
Take it apart by peeling away rubber cover and then remove two mounting screws. Carefully split cases and see where parts are arranged just in case they shift. Laser and lens frequently get jarred loose ESP in a golf cart environment. Place laser and lens if loose back in mounts and gluon in place with superglue or equivalent. Make sure to get no glue on lenses. Reassemble and it should be good to go again. Total time. Ten minutes maybe.
1helpful
What is the Bushnell Tour V4 Golf Laser Rangefinder product specification?
I have a Bushnell Tour v4 Golf laser Rangefinder.
Bushnell Tour V4 Golf Laser Rangefinder brings to you the next evolution of pin seeker with jolt technology. It provides an unbelievable pack of features set into a smaller and ergonomically sound form factor.
Here is the specification:
  • Product Dimension: 2.6 X 2 X 1.3 Inches
  • Pin Seeker
  • Color: White
  • Weight: 12 Ounces
  • Warranty: 2-Year Limited Warranty
3helpful
3answers
What is the difference between Hunting vs Golfing Rangefinders?
If you want to buy a rangefinder then you would have a question at some point. Can you use a rangefinder for both golfing and hunting? Can you save a few bucks buying one rangefinder?
The answer is Yes, you can. You can use a laser rangefinder for both activities if you choose a smart device that has features to serve both golfing and hunting adequately. You just need to know the basic differences between golf and hunting rangefinders and some limitations.
Fast of all you have to know, what is golf rangefinder and hunting rangefinder.
Golf Rangefinder Golf rangefinders seek for the nearest flag stick for the measuring the distance in an open field.
Hunting Rangefinder
The rangefinders always are in "Distant Target Mode" by default to spot wildlife in wooden terrains. This target set automatically ignores close objects that could obstruct your view.
Here I wrote the 3 difference, you should remember that:
1. First Target And Distant Target Modes
Golfers need "First Target Mode" to detect the near objects like flag or pin in an open golf ground. Hunting rangefinders rarely good at detecting close objects. For hunting, "Distant Target Mode" is appropriate to range a target past the wood. Modern rangefinders come with toggling options between both first target and distant target modes, but they are expensive.
2.Quick And Accurate Reading
Golfing rangefinders detect the object quickly, and hunting rangefinders give the accurate reading. It is true that golf rangefinders do not need to be as precise as hunting one. Hunters want to make sure that their prey can be perfectly located.
3. Magnification Strength
You might be aware of the fact that Hunting rangefinders always have more magnification than the Golf Rangefinders. Golfers need the distance of the next hole, which could be maximum 400 yards. For the bow hunters and hunting, 400 yards rangefinders are also appropriate. In case of rifle hunting or long-distance shooting sports, you will be needed maximum 1000 to 1500 yards ranges.
Now you know what the basic differences between the golf and hunting rangefinders are. You can start choosing your suitable one.
Apr 02, 2018 • The Optics
1helpful
2answers
Which is the best golf laser range finder?
Bushnell Scout DX Rangefinder is a good one for golf.
It's a fantastic rangefinder.
It offers some amazing feature and specification like...
  • 6x magnification.
  • Range between 5-1000 yards.
  • 3-volt CR2 Battery.
  • Rangefinder Accuracy 5 yards.
The Bushnell Scout DX Rangefinder will help you to pick from 3 different user modes by pressing the Mode button at the left side of the unit. First is the usual mode which can be used for most purposes up to 1000 meters and works well towards the pretty reflective surface.
When turned on, the Scout 1000 Laser Rangefinder liquid crystal display (LCD) will directly display icons like the bow and rifle mode. The bow mode will provide you with true horizontal distances from 5-99yd away, depending on the angle. The rifle mode, however, will permit you to get the angle and drop/holdover of your shot to the target from 100-800yd.
Mar 03, 2018 • The Optics
2answers
I purchased a new LR 559 Callaway golf rangefinder from a QVC auction. The problem with it is it isnt even close to accurate. I have a measured archery range back to 65 yards and the rangefinder is way off...
its a piece of ****, that happens when you arder through qvc. When you arder electronic devices for weights or measurements, first you must know exactly what you are looking at, make, model, and series,,, then read all of the reviews you can,, then go to a pro store-- (like our shop we are a pro archery shop) we refuse to work on peoples bows they bring in that they bought online, because half the time they recieved something that they did not order, they dont look like they did in the picture that the seller posted... always read reviews and ask the professionals.... I would return the item even if it was an auction, if you cant return it then ebay it-- but be honest when you post descriptions of the item, and the problems that you may be experiencing, trust me the buyers will appreciate it...
1helpful
I have a Bushnell Medalist Pinseeker golf laser rangefinder. I recently replaced the battery with a 9V Duracell Alkaline, and now the Pinseeker mode is not working (it will not sight different targets) and...
The "Pinseeker" mode is a automatic mode Sometimes it uses it, somtimes it doesn't. It is designed to recognize a vertical shaft. (Pin) Now IF you hold the power button down....you can see if all of the LCD segments are burning. If the segments fade out later in the game.... (bad LCD) Make sure the Pinseeker mode it on...(flag symbol on the left) Hit the button on the side if you need to. IF it still doesn't lock on to pins, it needs an alignment.
MTG
Bushnell rangefinder laser 400 golf shows an E 6 at the bottom and thats it. How to fix? its a 97 only used for golf worked fine put new battery in this year and I got the E-6 error
E6 means the unit has cpu or program failure....The only thing that bushnell can do is replace your unit with a newer one Its over 10 years old..... They won't have any parts or able to reprogram it.(they just do keep parts that long) They will offer you a model 20-1916 ($151.00 bill) (you can it see it @ bushnell .com.) The better model is........if you play golf is the Medelist(20-1354) or the Tour V2(20-1930).....The top of the line is the Pinseeker 1600(20-5105 without the slope function) or the Pinseeker 1600(20-5106 with the slope function).......If you hunt I would go with the model (20-1932 with the ARC fuction..... This is the real deal....call them
mtg
2helpful
Need a manual for Busnell 1500 Pinseeker Tournament
bushnell.com>north america>english>golf>laser rangefinders>Pro 1600 tournament edition> now look toward the bottom of the page and you will see the manual tab....you can download it to your computer. The 1600 and 1500 work the exact same way....the case and battery door are the only thing different!!!
2helpful
2answers
No I did NOT all I want to do is to be able to download a user manual for my Bushnell 1500 Tour edition pinseeker Lasr rangefinder w.slope
bushnell.com>north america>english>golf>laser rangefinders>Pro 1600 Tournament Edition> now look at the bottom of the page and you will see MANUAL. The 1600 and 1500 work exactly the same way. The only difference is the outer case and battery door. Trust me....
Top Yukon Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Yukon Optic Expert? Answer questions, earn points and help others
