Televison & Video Logo
Posted on Nov 25, 2017
I recently purchased the LG 47LH40 LCD TV & have so far kept the factory default setting. However, the caption is always streaming across the screen and is very irksome. I cant turn it off, as the Caption option is Grayed out in the Option Menu and dont know how else it can be accessed to turn it off. Thanks in advance.
5 Related Answers
Anonymous
  • 137 Answers
  • Posted on Dec 09, 2007
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
A
Anonymous
  • Posted on May 19, 2008
SOURCE: Closed Caption Option
CHeck on the comcast box- you may have to turn off (POWER) then click (SELECT)select button to get into the user interface , there you may see that closed catptioning is off, turn it on and it should work.
Anonymous
  • 1779 Answers
  • Posted on Sep 23, 2009
SOURCE: no closed caption
Take your cable and put it directly into the cable input jack on the set. Then turn the CC on and see if it functions that way. If it does then that means the CC circuitry is before the comp1 inputs therefor the dvr should have it's own CC setting because the set won't display it because of design.
Chi Chu
  • 8457 Answers
  • Posted on Dec 17, 2009
SOURCE: Cannot select caption? Its grayed out..
Tries the remote CC button on/off.If the station have captioning.Not in Text 1 or 2.
TODDAS
Todd Hill
  • 433 Answers
  • Posted on Jun 01, 2010
SOURCE: My Caption cannot be turned of
if you cannot turn it off in the menu go to menu/options and factory reset tv
I recently purchased used LG 37 (37LC2D) PICTURE WOULD QUIT READ ALOT OF PEOPLE HAVE SAME ISSUE. THEY RECOMMENED new main board i purchased one off internet $112 slapped it in and ba bam it worked an
Try to restore factory settings (default settings) to come back to original settings..In this procedure you can determine if the problem is on settings or on the faulty parts..
Thank you and hope it helps...
3helpful
Our brand new LG TV loses brightness whilst you are watching a programme.
Check to make sure that eco mode is turned off. It will sense the ambient lighting and if it is bright, the TV will be bright so if you are seeing the brightness change...check that setting first.
1helpful
I just bought an open box lg 47lh40. The TV remains on for about 15 minutes then begins to turn itself off and on. Any suggestions?
This is a circuit board issue. Your going to have to call LG and find someplace to have it fixed under warranty. Open box items cannot be returned so LG will give you someplace around your area to bring it for the repair.
1helpful
I have a cracked LCD on my Lg 47lh40
need replaced LCD panel
Manufacturer LGE Part Number EAJ60659701 Description LCD,MODULE-TFT
9helpful
2answers
My LG 47LH40 does not power on light at the bottom is off. What can I do it was bought last November
I just came across this problem. I called in, and they said there was a power switch right beneath the light on the bottom right edge of the tv. So I decided to look down there and it was switched to off. Switched to on and that was the problem. I didn't even know there was a button there, but apparently one of my friends turned it off while he was drunk.
1helpful
I have set my LG 47LH4000 to trumotion 100hz but when you press the ok button when watching it says 1080i 50hz should be 1080p
All TV signals, including SKY, are transmitted at 1080i and 50hz. The only sources for 1080p are Blu Ray, XBox or PS3
Tv will not change at all, nothing works, will only power on, no volume control no menu not nothing help!
Call your LG dealer to arrange a service engineer to update the current software on the TV & to re-set the system, this should remedy the problem.
4helpful
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
1helpful
3answers
White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
171helpful
21answers
LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
