Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
after the end of the entire washing, spinning cycle and the washer turns off, there is about a quart of water left in the bottom of the washer.
my frigidair washer will not drain or spin. when i turn timer knob to rinse, i can hear a faint buzzing noise from knob. when i go to spin, nothing happens.
