Hi, I have just bought a KIA Sedona 2006 model with a Rosen A7 system, i flipped the screen down and the DVD player screen came on without any problem, i then pressed the source menu button and the screen went off, i have put a dvd in and can get sound but can not get the picture back, also, now when i turn the engind off, the dvd stays powered up, any advice appreciated.
Put a cd in the dvd player then tune to the channel and it should work, then try a dvd.
When dvd player does not boot up and display the Kia logo, try moving the door as the hinge turns on the screen and sometimes the connection in the hinge can play up a bit.
there is an addendum in the owners manual of ours on page two saying only with VWs the A7 is not configured to provide speaker sound through the vehicle speakers. helpline number is 019332 732 331. We have a VW touran also and can't get it to work :(
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
Hi, The A7 has 3 sound modes. With the unit on press the speaker button and on the screen it will say either "Headphone sound only" or "Speaker sound enabled". Pressing the speaker button will toggle these modes back and forth. If you don't hear any sound when it says "Speaker sound enabled " it may be that it was wired using the FM Modulator, which means it uses the car speakers. For them to work, turn on your radio and tune it to 87.9 or 88.3. Good Luck!
