Resetting phones and restoring to full factory...
shared by 6 users
posted by omcjwc on Aug 18, 2008
don't know how to give a soft reset to both phones or to restore to full factory default. I do not have the manual which came with the phones.
thanks
The phone has caller ID menu button, and a redial/pause,select channel,delete/transfer and memory buttons.
Comment posted on Aug 19, 2008
I should have gone to the Uniden factory rep to start with. I was told by the Uniden factory rep that the phones can't be fixed ....will need to get replacements.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Posted by wargobs1 on Nov 01, 2008
When my phone rings,it only rings 3 times. Can I extend the rings
Posted by Guest on Sep 30, 2008
I have a phone that will not deregister. It keeps saying that it cannot connect to the base. I am trying to reregister because two phones have the same phone ID. I tried resetting, but there must be DRAM, since leaving battery out for a couple of days did not erase info
Posted by Guest on Sep 04, 2008
I have no power on phone it will not power and I have had it for less than two years it was purchased from Conns appliance is that where I should return it to.
Posted by Guest on Aug 28, 2008
I can call out on phone but cannot recieved any phone calls.
Posted by dlechem on Aug 24, 2008
I have a Uniden 7805 phone that I need to reset. Saw on the internet to removethe battery and then press and hold the '*' and '#' buttons while replacing the battery, and then pressing the RH soft key. Did this got the place on base message - but stil will not register!
In a male moment decided to do the same thing to one of the other phones that was working - so now have 2 phones that do not talk to the base unit!
Solution #1
Thanks for Trying (70)
Fixe_You
Rank:Wiz Wiz
Rating: 81%, 323 votes
okay i will fix the prob but i need model name
and fix ya rate after giving the solution okay??
okay its up to u
Rating Locked! (?) omcjwc has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Resetting phones and restoring to full factory default.:
I don't want to Accept this solution
Can you Help with these Phones problems?
Uniden 5.8GHz Dual Cordless Expandabl Phone
5.8 GHZ digital 2 uniden hand phones
states that voice messaging is not active. this phone...
The menue will not come up when depressing the key on one...
I have a Uniden 5.8GHz cordless answering machine with two...
My daughter was playing with my Uniden powermax 5.8ghz...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Telephones
(207) 894-7100
We repair business multi-line telephones and...
Priority One Phone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
