Hi Dishwasher not draining issue usually occurs due to
kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for
any visible clogging, remove if present. If no visible lint is present then
remove then turn off the dishwasher and remove the drain hose and check for any
visible clogging. If it's still not visible then the drain filter or drain pump
is clogged and you'll need to clean the drain filter and drain pump. Also,
check for any food pieces stuck near the pump impeller. Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat. Hope this helps... Please post back for any further
assistance. Daniel
