I ahev installed a LITEON dvd.cd writer When I try and burn info onto it a message comes up NO CD IN DRIVE. I had the same problem with my old dvd writer but putting a new one in hasn't solved the proble,
PLEASE HELP
Comment posted on Aug 20, 2008
HI
DIDN'T KNOW WHAT YOU MEANT BY RUNNING FILTERCHECK, PLEASE CAN YOU EXPLAIN HOW TO DO THIS
THANKS
run filtercheck 4.6 or some tool to remove upper and lower filters.
Comment posted on Sep 12, 2008
if you go to google.com and type filtercheck 4.6 a result says cdr-zone.com ... that one.
Comment posted on Oct 06, 2008
wow i seem to not be geting emails when people reply. ok first. was drive new or used.? i have same drive and its 2 yrs old. or its software issues. can you boot from a cd like windows or linux? there is a software that removes what is called "upper and lower filter" which can cause this issue also.
its either hardware or software. first find the source. then fix it.
Rating Locked! (?) kenlloyd1947 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dvd writer:
