Question about GE Spacemaker 26976 Cordless Phone
Had a power outage during a lighting storm and now the GE spacemaker phone/unit does not work; it's showing in the display screen "Initializing". The phone works, but when you press any of the buttons on the unit, it doesn't change the display screen. I have checked all other appliances, TV, DVD players etc, and they are all working okay. I have unpluged and repluged back in, but again just come up with the same thing. I have checked the manual, but cannot seem to find anything that will change this. Please advise
    New Friend:
  • 37 Answers
Does it have a battery backup? If so, after disconnecting the AC power adapter, remove the battery for 15 minutes, then re-insert it (make sure it is a good battery), plug the AC adapter back in, and try again. Hopefully, this will re-set it. If not, it probably isn't worth tryiing to repair. May have to buy a new phone.
Posted on May 06, 2017
SOURCE:
Indian Guru
  • 32 Answers
SOURCE: Beep During Conversation
i want how frequently it occurs if it occurs always or sometimes like 1 in 10 times like that and which country you are who's ur provider
Posted on Apr 25, 2007
  • 201 Answers
SOURCE: Ge cordless 900 mhz home phone
What is "Bell" and "Cogeco"? Did you change phone line provider companies? If so, you would need to ask them if it's possible to change. You are getting the information they are sending you. I do not believe the information is being altered by your phone.
Posted on Jul 07, 2007
SOURCE: whont work, please register in displayed on screen
To solve the register problem.... Put each phone for 20 seconds or so in the main base. I had the same issue, and resolved it this way.
Posted on Aug 27, 2007
SOURCE: Ge 25932ee1 5.8 Ghz Edge Series Cordless Phone
MicrowaveSvc
  • 9174 Answers
SOURCE: Dead GE Spacemaker
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open.
When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Oct 22, 2007
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
I have a GE Spacemaker XL from 1998. It was working fine yesterday but today the display window shows all asterisks. I have unplugged it for several minutes in an effort to reboot it. It asks for a...
Wow! sounds really weird. Possibly Microprocessor on Main Timer board. No way to really diagnose other than substituting or replacing the main board. Unfortunately a bit pricey. Nothing else i can think of that would actually cause asterisks in the display. I really do not like to refer them, but may need to call GE since it is one of their units. Maybe they could give you some guidance. Mostly, over the phone, they just insist on sending someone out. So they can bill you more.
Aug 23, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Nothing shows up in the display. This has only been recently after a power glitch. The display lights when a call is made or received.
I unplugged the base unit from the wall for more than 10 minutes. Sometime after I plugged it back in (not immediately)the display re-appeared.
Nov 16, 2009 | Panasonic KX-TG2631 Cordless Phone
There is power to adapter but not in spacemaker unit
is there anything suspicious that you can see in the unit?like blown-out or busted? is the power switch on?
Jun 21, 2009 | GE SpaceMaker 05GP009 Television
GE ZEU36 leds turning on in cascading effect repeatedly when power plant on
50Hz or 60Hz alternator?
circuit board on the stove may be frequency locked
Oct 30, 2008 | GE Monogram ZEU36 Electric Cooktop
GE Spacemaker xl model#jvm1330ww005
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If it's still out, the problem may be on the control panel, which we regularly repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | Microwave Ovens
Philips display went out when power outage occurred
I can supply a replacement display from a scrapped unit, I'm in the UK, search on ebay for seller fluffcat1 and contact me.
Oct 04, 2007 | Philips CDR775 2-Disc CD Recorder
GE 25931 Cordless Unavailable
I had the same problem recently due to a power outage during a storm. GE advised to disconnect the power cord and telephone cord on the "mother" unit. Wait five minutes. Then plug it back in.
I placed the "mother" phone back in the base. After the screen flashed on the "mother" phone, I removed it and then put the other two portables in the "mother" base.
This corrected my problem and all is now well.
Jul 31, 2006 | GE 25931EE1 Phone
GE Spacemaker 26976 Cordless Phone Logo
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
