SOURCE: I have a systemlink 4
You can find the remote control codes for difrent brands of
devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just
yet. Please post back as to what steps you took, results, etc, and I will try
to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: RC64 remote will not work with my RCA surround sound RT2580
I hate to say it's unlikely that a "Universal" remote from DirectTV has compatibility with every system and manufacturer. However, my directTV model remote (and there are numerous ones) has a search function with which you don't need to enter a code... it finds one for you. If the control documentation doesn't mention such an option (Code Find), then I'd say your SOL. I'd recommend a Universal Remote made for no specific purpose but to be a UR... using a system included UR never comes off very well.
SOURCE: need 3 digit code for rca tv & universal URC-21XXXB01
I need the digit code for my remote control - RCA TV
SOURCE: DirecTV remote won't work with my new RCA TV
yes go into kitchen open bin drop in these remotes are not meant for our tv/dvd/sat etc they are for a chinese system save your hair chuck it away sorry to say I got one of these oh dear !!!!!!!! you would be better getting a sky type copy remote from the two pound shop I did works great
