Motorcycles Logo
Posted on Jun 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 kawasaki 110cc took apart back tire area and have a thick metal cylinder shaped object and forgot where it goes
Anonymous
Level 2:
  • Expert 252 Answers
  • Posted on Jun 08, 2011
Anonymous
Expert
Level 2:
Answers
252
Questions
Helped
173631
Points
510
Hi there hicks32
that metal object is a rim loc , it should have a rubber top bonded on it , this fits into another hole other than the one that the tube valve stem goes into
you should have 2 holes ,fit rim tape, fit one side of the tyre bead, instal rim lock ( with rim tape running over the rubber on the rim loc ) fit the washer and nut losely on the rim loc bolt stem by at least 4 or 5 threads fit the tube as you normally would, push the rim loc stem fully up ( so that the nut rests on rim )do not let the rim loc stem receede into tyre ) refit the other tyre bead and inflate the tyre and seat the beads on the rim , tighten the rim loc nut and the valve stem nut
make sure that that both rim loc and valve stem are straight when inflated and tightened
refit your wheel
cheers pauly46
I took apart a TDK Video Cassette, and I can't put it back together! I have two small metal cylinders left over, and can't for the life of me figure out where they should go! Please Help!! Thank you
The two metal cylinders are guide rollers where the tape goes in and out of the cassette. If you pick up any VHS tape and press the little button that allows the flap to come up, you should see them.
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Front tire clicking noise?
Take the car to a trusted tire store and have them dismount the tire on that wheel to look for an embedded rock or metal piece in the tread area. It may not show itself from the outside due to lack of weight on the area of interest, but an internal inspection may show it up. Try putting the spare wheel on to see if the sound goes away. Hope this helps!
1helpful
How to get the blinker switch assembly out of a 1966 oldsmobile 98?
1966 Olds 98?
It's been a while, so bear with me. The main objective is to remove the steering wheel, to have access to the turn signal switch.
1.Negative battery cable disconnected
2.I believe you twist the horn button in the middle of the steering wheel, and pull up, to remove. The horn button should have a ring of thick rubber on the bottom, which keeps it in the steering wheel. The chrome piece under the horn button may come off with it, or it stays on the steering wheel. This is the part that is fuzzy to remember.
3.Remove the steering wheel nut, and lock washer.
4.If you do not have a steering wheel puller, go to your nearest auto parts store, and see if one is available to rent. The cost of this puller is relatively low, so you may just want to go ahead, and purchase one. While you're there you need to obtain another tool also. Steering Wheel Lock Plate Tool.
5.After the horn button is removed, and the steering wheel nut, you will see a flat metal area of the steering wheel. On each side of the threaded part of the steering column shaft, there are two small threaded holes, in this flat metal area.
The steering wheel puller, is a bar shaped piece of metal, that has a threaded hole in the middle. There is a threaded shaft that goes into this hole. On each end of the metal bar are slots. Threaded bolts go through these slots, and line up with the two threaded holes in the steering wheel. There is a pointed tip, that rotates on the threaded shaft, of the steering wheel puller. This pointed tip goes in the middle of the steering wheel shaft. (The shaft that you removed the nut from)
Find the two correct threaded bolts in the steering wheel puller kit, that matches the threads in the steering wheel holes. They HAVE to be the correct size, AND the correct thread. (Fine thread, or Coarse thread. They will be SAE thread, and not Metric) If the puller does not come with bolts, or the correct bolts, you'll have to purchase them separately.
Place the puller on top of the steering wheel shaft. Run the threaded shaft of the puller down, until at least 3 to 4 threads of the shaft, are showing on the steering wheel side. Now place a threaded bolt in the slot on the outside part of the bar.
Run the bolt down into the steering wheel threaded hole on one side. Make sure it goes in at least 1/2 inch. Do the same with the threaded bolt for the other side.
Adjust the length of the threaded shaft of the puller, so that the two outside bolts will go in as advised. Adjust the threaded shaft out, or in. Be SURE the two threaded bolts, are threaded down into the steering wheel the same depth, and the bolts are the same length!
Now turn the threaded shaft of the steering wheel puller in, with a ratchet and socket, to remove the steering wheel. (Turn the shaft to the Right)
6.Now remove the steering wheel lock ring. The steering wheel lock ring tool is now used.
There is a cylindrical shaped piece that has threads on the inside of it, and has a hole at the top, that a lock pin slides through, for the above tool. This cylindrical shaped piece is threaded down onto the steering wheel shaft.
The tool has a handle shaped like a screwdriver handle, and a shaft attached to the handle. The shaft goes down into the cylindrical shaped piece. Then the lock pin goes through the cylindrical shaped piece, and also a hole in the shaft of the tool. This lock pin locks the cylindrical shaped piece to the shaft of the tool.
BEFORE the cylindrical shaped piece is pinned to the shaft, you slide a U shaped piece up on the shaft. (Thought it would be better to explain it this way)
The opening of the U, goes down towards the steering wheel. It's U shaped to clear the steering wheel shaft.
As you turn the handle of the tool to the right, it pushes the U shaped piece down. The U shaped piece then depresses the steering wheel lock ring down.
(There is a Thick metal spring under the steering wheel lock ring)
You have to take a metal pick, and a small flat tip screwdriver, and remove the round snap ring. May take a little finesse, and a few tries. Use patience. Now back the steering wheel lock ring tool off. (Turn to the Left) The steering wheel lock ring will come up, so that you can take it off. Remove the spring. Remove the plastic horn contact assembly. Now you can see the screws to remove the turn signal switch.
3answers
1996 vulcan 1500, clutch goes away
if your oil is too thick , your clutch will sleep and go away .
if the clutch is old , you obviously will have the same problem .
please explain your problem when you ride
I took the driverside back tire off put back on and now wont rotate plz help...
take the tire off. Look at the axel and the tire. notice the groove on each. There is usually a small metal keyway that aligns onto the tire and the axel together. usually a 1/4 sqaure metal stock. might have to look for it in the area you removed it. Find it grease it up abit and align them together that will fix you problem im certain. -Regaurds.
Oil leak
the round oval shaped object in question should be the canister where your oil filter goes ,yes there is a gasket on the inside that may have been broke or left off on your last oil change
Took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Dec 02, 2008 • Wahl 8550
ID a Fairmont part?
it sounds like it is a frame support, there should actually be a rubber bushing on the top of the washer, the bushing more than likely dry rotted and fell off.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
