Jura Capresso Impressa X90 Espresso Machine Logo
Anonymous Posted on Jun 07, 2011
How do you open a jura x9 - Jura Capresso Impressa X90 Espresso Machine
acehead
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 107 Answers
  • Posted on Mar 23, 2015
acehead
Expert
Level 2:
New Friend:
Cheetah:
Answers
107
Questions
0
Helped
102284
Points
113
Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Is it possible to start using a filter on the Jura Impressa x9 without getting a technician out?
yes, you can do it I did it on a friends machine, when you install the first time the machine guides you.
My jura x9 says rinse fill
This happens when the machine is priming the thermoblocks(heaters) the machine is not registering water flow through the machine.blockage in water tank? pump not running? a thermoblock scaled up(blocked). first check the 2 flow meters in the machine located under the water tank. one of these may be defective or just stuck,
Jura x9 water tank fill rinse
So what's the question?
https://www.capresso.com/customer-care-instruction-booklets.shtml
Jura impressa x9 classic.
this problem is normally due to the flow meter not sensing water flow through the machine. possible causes are 1,lime scale in the thermoblock this may need replacing. 2, the pump has failed also may need replacing. 3. the flow meter itself is stuck , this can be dismantled and cleaned, if not then replacement is required. 4. a simple blockage from the water tank to the inlet . not a job for the novice..
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
