Nady Systems DKW Duo Microphone Logo
Posted on Sep 05, 2017
Microphone/audio PA system generates annoying high frequency audible squealing noise when connected to Nady DKW-Duo wireless system through an unbalanced XLR 1/4 Inch male to 3-wire female adapter to the microphone input on the PA system. Any modification, application, or technique available to replace this output adapter that appears to be the antenna for the problem?
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Aug 22, 2007
SOURCE: Samson CL7 Connection
is the light indicator on?
Michial Gueffroy
  • 1140 Answers
  • Posted on Oct 19, 2009
SOURCE: Want a wiring diagram for 1x3pin xlr plug to
Pin 1= ground/shield, Pin 2= hot(+ve), Pin 3= cold(-ve). Just remember if you make a cord like this you can expect some signal loss.
Anonymous
  • 87 Answers
  • Posted on Oct 23, 2010
SOURCE: i got a cable to hook my MXL 990 condenser
Professional condensor type mikes require a phantom power source to work. That will be a balanced (read XLR) connection from source to preamp and the preamp must be capable of supplying the power. These units cannot be used in an unbalanced circuit (like 1/4" or computer mini-pin). Your best bet for the setup would be to get an external power supply box that can also convert the signal from balanced to unbalanced. That would be what the mike plugs into and then that plugs into the computer. You're probably looking at about 50-100 for even a cheap one that will work well. Companies like Sweetwater and B&H should be able to steer you toward a decent basic unit. If you happen to have a mixer (which is why you bought the good mike) then it may have phantom power for some of its mike inputs.
valeantudor
Tudor Valean
  • 787 Answers
  • Posted on Feb 14, 2011
SOURCE: We have a Nady Duet
This usually happens when you keep your microphone too close to the speaker. Does this happen also when you keep you distance from that speaker?
mydjgary
  • Posted on Jul 22, 2011
SOURCE: I bought a samson se50 headset microphone to go
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Mixer to P.A. system connection
You'll want to use the Stereo Out connections at the top right. You might need adapters to plug into whatever system you're trying to use. Also note that this mixer does not provide power, so the speakers you're using have to be self-powered or be driven by a separate amplifier. You would then plug the Stereo Out connections into the INPUTs of the amplifier.
No sound from my 2 year old Nady MPM 4130 pa system
Very likely source of this problem is the "mixer out/amp in" jack on the back. Anything plugged in there breaks the signal path so, obviously any off board equipment plugged in there needs to be checked...but that jack itself could be faulty or even just dirty. If there is nothing plugged into it....you can get a phone plug (power off) and plug in and remove it a few times. This is a switching type jack so if the "switch" part of it isn't connecting with nothing plugged into it, the signal path would be broken and give you the results you've been having.
3helpful
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Nady Ht-duo cordless microphone, new 9 volt battery. Red battery light should stay on, but comes on then goes out. Checked contacts, no problem there.\r\n Thanks,
Nope.
The red light should blink when turned on and then go out. That is normal. When the red light stays on, the battery needs to be changed.
Dan
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
Neeed my NADY 151 VR repaired. Can somebody do
Take it to a music store that sells and services Nady products.
Humming noise
If this is like my unit it is a high pitched squeal. I received my unit as a gift for Christmas 2007 and I thought it was defective. I contacted Homedics and they sent me a replacement but the problem persisted. As licensed amateur radio operator I am versed in electronics so I decided to track down the source of the noise. It turns out that the 16VDC power adapter is the source of the noise. It is what is called a "switching power supply" and is unfortunately not well filtered causing the high pitched squeal. I was able to get rid of the noise by modifying the power adapter and adding a 2200 microfarad capacitor in parallel with the output. This filters out the high frequency ripple and gets rid of the squeal. An alternative solution would be to search the Internet for a better 16VDC power adapter. It must supply 2 amps of power and have a 5.5mm OD/2.1mm ID center positive power connector.
Top Nady Systems Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Nady Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
