Singer 8280 Mechanical Sewing Machine Logo
Posted on Jun 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Singer 8280 (prelude) I had 2 threads coming out from my bobbin area, so I decided to open it up and take a look. I accidentally took out the whole bobbin shuttle. The manual doesn't tell me how to put it back together, it does tell me how to take it apart for cleaning. The actual bobbin is in the case & I wound it up. The case with the bobbin in it snaps onto the hook. But I can't get the bobbin holder and the hook to fit into the machine. The clips won't hold down the holder because something isn't lined up right..Help.
Anonymous
Level 2:
  • Expert 244 Answers
  • Posted on Jun 07, 2011
Anonymous
Expert
Level 2:
Answers
244
Questions
Helped
76043
Points
566
Ok, hang on! This can get tricky! Remove the bobbin. Remove the presser foot and the needle. Remove the throat plate. This gives you plenty of room to monkey with your bobbin case. NOW, lay the bobbin case in its correct area and gently rotate it until it falls into place. It may take several tries. Once you're satisfied that it's secure, snap the holding clips into place and it should all fit nicely. THEN place your bobbin in the case correctly...check the diagram in the manual. Depending on the machine, some bobbins have the threads coming off counterclockwise and others have them coming off clockwise, but your manual should show. Sometimes, there's even a diagram on the throat plate or the bobbin case as well.
Good luck. Hope this works. If this solves your problem, please come back and rate my answer!
Singer prelude 8280, entire bobbin case came out in two pieces. I don't know how to put it back in.
refer online on utube on 'singer installing a front loading bobbin case threading & insertion'
Singer Prelude 8280 Sewing Machine stuck
Is the knob on the side, where you loosen the needle to rewind the bobbin, tightened? Also, there may be some threads in the bobbin case messing things up. Unplug the machine if you are checking the bobbin case.
3helpful
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
I have had a singer prelude 8280 for a year now with no problems. now all the sudden the thread is catching in the bobbin casing. The thread on top looks normal, but when you turn over the fabric...
It is in your top threading, try this test, rethread, now with the presser foot up, pull the top thread, it should feed smoothly, now lower the presser foot, it should barely move. Sometimes this seats the thread in the tension discs. Also, make sure that your needle is fresh.
change the needle
clean under the needle plate where the feed dogs are for lint
make sure the thread has not come off the thread take up lever
rethread the machine
Breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
1helpful
2answers
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
