Your print head is clogged, or you are running into trouble with the smart chip limiting the number of prints. Go into the printer properties and select the maintenance tab. Run the deep cleaning function and print the test pattern up to 3 times to get a good printout. If that doesn't work you may need to reset the print count chip. Advanced technology Original ink cartridges use their "Smart Chip" to limit the number of prints. CLICK HERE to see an example. If you are still having problems the printhead itself may need to be cleaned manually. If you get to this stage message back and I will give detailed instructions.
