SOURCE: lens comes out, retracts right away, no noises
First make sure your camera's battery is fully charged next take a can of compressed air and blow air around the lens to try and clear any debree that might be in the way. hope this helps
SOURCE: Casio Z750 says, "Lens Error" on start up, and then shuts down?
A lens error has to be sent into repairs or else you need to buy a new camera. Repairs is 800-706-2534 and then choose extension for repairs.
Katie, Joe alerted me to your problem. The symptoms that you're experiencing suggest that you're experiencing a lens error. Lens errors are fairly common, but there are many causes. Some causes include poor or drained batteries. Or sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
