Hi Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll up until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say, "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to "Signal Descale" and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
SOURCE: Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
SOURCE: my coffee machine says decalcify
Try to make a cup of water ( like you do tea), if it not work then you have to replace the magnetic valve inside the machine
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
SOURCE: coffee machine blocked
it could be grind stuck in the (yes the, as in the only) hole in the filter cup. remove the filter cup from the cup holder (the thing with the black handle) and use the tiny pin in the little brown tool to push out whatever is in there. you may have used to fine a grind or stuffed the filter cup too much. careful, that is how you break the plastic filter holder ring.
for calcifying, i just use plain white vinegar. i put it in straight into the clear water holder, about 3/4 cup, then i run it throuhg a bit, let it sit 5 min, run it through a bit, let it sit 30 min to an hour. depending on the day, i repeat a few times, rinse with clean water. i do this about every 2 months.
