Almost all Windows operating system users come across system errors
at one time or another. A flickering or blank screen, frozen cursor,
blue screen, or an unexpected system restart are all indications of a
system error. Most of these errors display an error message that you can
use to troubleshoot and fix the problem. In this article, we will learn
about the code 10 error and then have a look at common causes of system
errors and methods to prevent them.
How to Fix a Code 10 Error
A Code 10 error usually occurs due to:
- Missing device driver
- Malfunctioning device driver
- Incomplete device driver files
If the device due to which the error has occurred contains the value
FailReasonString
in its hardware key, then this string is displayed as an error message.
Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device
driver for the faulty device. To update the driver, select the
System option from the Control Panel. In the System Properties dialog box, select the
Hardware tab, and then select the
Device Manager
button. Scroll through the Device Manager window and identify the
faulty hardware device. Right-click on this device and then select the
Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
- Device driver conflicts
- Corrupt or damaged software files
- Malfunctioning hardware
- Corrupt or damaged system registry
- Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent
most system errors. Some of the tasks that you can perform to prevent
system errors are listed below:
- Keep your operating system, device drivers, and software
applications updated with the latest hot fixes, security releases, and
updates.
- Run regular antivirus and anti spyware scans
to keep your PC free from harmful and disastrous malware. Always keep
these software updated with the latest security releases so that your
system is always protected against malware infections.
- Avoid opening attachments of unsolicited emails and visiting dubious websites.
- Do not download freeware and shareware from websites whose authenticity you aren't sure of.
- Be very careful while downloading ActiveX controls from various
websites. ActiveX controls provide their master with complete control
over your system and therefore, a malicious ActiveX control can cause
severe damage to your system and may also enable a hacker to steal your
personal information.
- Last but not least, perform regular registry maintenance to ensure
that your registry is free from errors. 90% of all system errors are
connected to the system registry in one way or another. You can easily
perform registry maintenance with the help of a registry cleaner such as
RegGenie.
This software will provide you with a simple-to-use graphical interface
and enable you to scan and clean registry errors in just a few mouse
clicks.
System errors are common on Windows systems and can occur due to a
number of reasons, including problems with device drivers, hardware,
software applications, and the system registry. Code 10 is one such
system error that occurs due to problems with a device driver. You can
fix this error by updating the faulty device driver. Preventive
maintenance with the help of antivirus software, registry cleaners, and a
certain amount of vigilance while working on the Internet can help you
keep your PC free from system errors.
Additional Recommendations...Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A
driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
