Question about Whirlpool Washing Machines
Whirlpool duet wahsher
Displays code f11 and wont continue cycle
  • comeonref Sep 23, 2008
    most of the time it reads an error "F 07" and stops completly,
    does anybody knows what this means? I tried pause/cancel
    and re-star but the error keeps coming back,
    any solutions?
    thank you
  • 594 Answers
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Posted on Aug 18, 2008
SOURCE:
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Whirlpool Duet Sport Model WFW8300SW0 basket won't
    The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    NOTE: If the error remains on the display, call for service.
    I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
    Hope helps.
    Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
    I keeg getting the dreaded F11 anf DL code!
    PLACEHOLDER FOR ART
    Take care
    Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
    F35 code
    Take care
    Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet washer shows error message "F 06"
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
    Pl give me a ‘very helpful’ rating for the free help, thanks.
    Jan 29, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
    Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
    Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet gas dryer PF error will not reset as per manuals
    PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Error code f35 on my washer
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    ERROR CODE F71
    Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F11 code Whirlpool Duet GHW9300PWO Washer
    well your close f11 is a motor control unit error or a loose connection in the wiring harness from the mcu to the motor or from the mcu up to the control panel the mcu is under the bottom kick panel un plug the washer safety first then start at the motor follow the wires back to the mcu checking wires and connectors then form the mcu up to the control board check your motor for continuity normal should be about 6 ohms between pins 1&2 then same at pins 2&3 same at pins 1&3 your motor maybe overheating and tripping out on overload then restarting when the washer motor cools down if all that checks get back with me and we will run diag on it
    Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    2,699 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
