The reasons for the "No disc" issue are various. In order to solve the problem more precisely, you can refer to the followings reasons and select the most solutions.
1. Incomplete disc information or scratched disc. This is the main reason for the issue. Before you try anything to examine or fix your DVD player, it's suggested that you make sure the disc you are trying to play is intact and well. If it's the problem of your disc, then trying to fix your DVD player does not help at all. In this case, you can copy the scratched DVD disc and then you may play it on your player machine.
Source: How to fix a DVD "No disc" error (3 solutions)
Play it in other drive, If will read, you can be sure, taht your rom is original, and that problem from burn.
it was an option.THEN (day1 new)2008
there are 3 choices to learn this fact.
device manager see if odd is blu-ray
run free app, HWinfo32.exe. google and run it.
or pull the drive and read the label see below.
even in 5 color choices, how cute.
OK, i looked at he drive, and has no logos
for Blue ray, in fact the bezel devoid of words
or icons or logos.
so remove it via the locking screws.
and look here,
I don't think that model came with a blu-ray drive. I would look at the side of the drive and make sure it specifically says Blu-Ray on it......unless you get a blu-ray drive as a special option, I doubt your laptop has one. Thus, it would not be able to play blu-ray disks.
Good Luck
most did not then
ok, if drive(ODD) present is BR
then what is wrong now.?
or the BD disks is bad, scratched or cracked.
the BD is not real movie sold in stores, a clone or copy of one and is dead. send it back.
or from the wrong region.
or running virus magnet XP or vista now. infected OS.
The BR drive has the wrong driver loaded or is missing in device manager.
does a 2nd BR dick play ( 2nd title)?
the actual drive must be Blu-ray to play them.
