Broderbund Print Shop® 21 Pro Publisher Deluxe Full Version for PC Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Print ship Pro Publisher Deluxe which is not working with my Windows Vista in converting the file to pdf. The Broderbund pdf printer will not set up. It keeps telling me there's an error in registry. Can I fix this?
Anonymous
Level 2:
Sergeant:
  • Expert 212 Answers
  • Posted on Jun 06, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
212
Questions
0
Helped
55869
Points
632
I would try installing another pdf printer, like the free PDFCreator. That way you could just choose a different printer from your Broderbund software, and print the same file to PDF.
Give it a shot :)
Good Luck
Why can't I save to a PDF with Windows 7?
The Broderbund PDF converter is a piece of software that is apparently bundled with Broderbund's Print Shop. If you upgraded your OS, you may need to update your Print Shop software. If you did a "clean install" or had your XP operating system saved to an Old Windows directory, it is likely that you will have to reinstall Print Shop in its entirety.
In case it helps, here is an article on someone with a similar issue:
Amyuni Technologies
2helpful
2answers
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
1helpful
Can't save doc as pdf
You will need some special software to print to a pdf file. A popular and free one is cutePDF. You can download it here:
http://www.cutepdf.com/products/cutepdf/writer.asp
Once you have it installed, open up the file you want as a pdf and then go to print it like you would if you were going to send it to a printer. Once the print window pops up change the printer to "CutePDF writer" and then click print. It will ask you where you want to save it and voila...your file is now saved as a pdf.
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000} --------------------------------------------
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
1helpful
Will the Print Shop 21 Pro Publisher Deluxe run on Vista?
Hello Friend,
This version is not supported by Vista, you have to upgrade it to "The Print Shop® Pro Publisher™ Deluxe 22 " version.
Visit the link below for more details:
http://www.lazydesis.com/software/72024-broderbund-print-shop-pro-publisher-deluxe-vista-ready.html
Thanks,
Shiva
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
I've installed Printshop 21 on my new computer. I
Go to Control Panel,, Click Install New Hardware,, it will search for anything NEW, then ask you if you want it to automatically install the Drivers ! Click YES !
2helpful
2answers
My system is windows vista 64 bit. Print shop
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
1helpful
Does not read .sig files
Small text file that can be automatically attached to the end of e-mail messages; usually includes the sender's name and e-mail address; in work-related e-mails, the signature may also include the name of the person's company, the person's title, and contact phone numbers; some people choose to include a quote or Bible verse in their e-mail signature.
Most e-mail programs support multiple signature files; they can usually be selected from within the create new message window. Program(s) that open sig files mac.gif Mac OS tri.gif QUALCOMM Eudora Pro
windows.gif Windows tri.gif QUALCOMM Eudora Pro
tri.gif Microsoft Outlook
tri.gif Microsoft Outlook Express
Broderbund Sign File Popularity 3.gif Average Category Image Files File Description Image format used for signs and posters created with Broderbund graphics software, such as PrintMaster and The Print Shop; can be opened with the program that created the file and possibly with other Broderbund programs or versions, but compatibility is not guaranteed. Program(s) that open sig files mac.gif Mac OS tri.gif Broderbund The Print Shop
windows.gif Windows tri.gif Broderbund The Print Shop or PrintMaster
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
