It sounds like there may be an issue with the ignitor switch for the large burner. Here are a few things you can try to troubleshoot the issue:
Clean the ignitor: Sometimes the ignitor can become dirty, which can prevent it from working properly. Try cleaning the ignitor with a soft brush or cloth to see if that helps.
Check the wiring: Make sure the wiring for the large burner is properly connected and not damaged. If you're not comfortable working with wiring, it's best to call a professional.
Replace the ignitor switch: If cleaning the ignitor and checking the wiring doesn't help, it's possible that the ignitor switch for the large burner is faulty and needs to be replaced. You can find replacement parts online or through a professional repair service.
Call a professional: If you're not comfortable troubleshooting or making repairs yourself, it's best to call a professional appliance repair service to diagnose and fix the iss
Hi- most likely the spark module is bad. Sometimes a burner swith gets stuck as well. Unplug the unit, the plug should be inside the cabinet. Take off the knobs and see if you see any obstructions and see if the knob posts move freely in and out (push to turn). Probably need to get a Tech out to look at it. If it is clicking even when the burners are off you can just leave it unplugged and light with a match to use it. If it is only clicking when you have the burners on check to be sure all the burner bases and caps are assembled correctly and seated, sometimes the electrode will continue to click if the burners are assembled wrong or are wet. Hope this helps a little. Good Luck.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
one of the switches is still stuck on ignite try to isolate which one it is most likley there is still liquid causeing it to stick ie grease something stickey check the valve that sends gas back to the rear burners again it sounds like not all of the liquid has been removed look closley and always be safe
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
