Yes, the waveguide (duct) cover protects the waveguide and the magnetron from damage caused by grease and food particles getting on them.
The
waveguide cover (also called a spatter shield) is usually about the
size of a playing card and often held in place by a plastic rivet.
It can be fragile, and
the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal
behind it should be cleaned with a mild, non-ammonia cleaner.
If the area is charred or chipped, the area will
first have to be sanded smooth and
cleaned and dried thoroughly.
If the cavity metal of
the oven is cracked or split, you can use a small amount
of steel-based epoxy such as JB-WELD
to patch the crack or hole.
Once that dries
thoroughly, you can sand it very smooth.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
If your
waveguide cover
is burned, it will need to be replaced.
It provides critical
protection for the magnetron.
You can order a new waveguide cover form Encompass here.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
DO NOT try to
REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST
PRESET VOLUME on the board. It is very dangerous to repair or adjust
without sufficient test equipment because this circuit handles very
high voltage and very large current. Off alignment or inverter board
operation is dangerous. Operating a misaligned inverter circuit is
dangerous due to the very high voltage and current that is produced
by this board. Defective boards must be replaced with a new one.
Consult an approved Panasonic Microwave Repair Service.
H97, H98 and H99
appears in display window a short time alter start key is pressed and
no microwave oscillation.
NOTE:
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
