Logitech LS-21 2.1 Speakers Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The sound on the speakers is really quiet and i dont know what to do.
Anonymous
Level 2:
New Friend:
  • Expert 104 Answers
  • Posted on Jun 06, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
104
Questions
Helped
15378
Points
288
Try using an earphone on the system, if it works properly ( that is if the sound is good and normal) than probably your sound IC needs to be replaced as it is wearing out.
G.
  • Anonymous Dec 07, 2012
    I'm having the same issue. How would I go about purchasing a new sound chip (I assume that's what "IC" is?) and also, how to install?
Describe your Magnavox Stereo Mini System FW36 Problem My speakers that came with the stereo dont really work. only when I turn the volume all the way up I can hear the music, but the sound is really...
Yes.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
So i just bought the coby dvd938 and i hooked it all up and all the colors are correct and the pocitives and negatives are correct but the only the front 2 speakers and the subwoofer work but i cant get...
Yeah I'm having a similar issue. Front speakers and center speaker working fine but rear speakers are very quiet and the subwoofer isn't working at all. Everything is connected correctly as well if you figure something out let me know.
2answers
Speakers are REALLY REALLY quiet. Help?
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
2helpful
Still sounds like my speakers are in mono
Make sure that the speaker config is set to stereo or surround, depending on speaker capabilities. Once you run the speaker config in sound devices you should be all set. Hope this helps.
1helpful
Sounds like my speakers are in mono
Go into the control panel and choose a different speaker setup.
Bloom speakers only emit very low sound after being connected
well i dont know what to do except turn your volume on really high and make sure its plugged in. no they dont need batteries; i got mine today and its not that quiet its blue and i think its okay. but i dont know if its that bad you should return it. mine was only 7 bucks
My pioneer sounds really bad
Check the antenna input...sometimes these come loose
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
I have a Philips FW- M777 Hi-Fi unit, which i was using the other day at a relatively low volume, no more than 25/40 when all of a sudden there was a burning smell which may or may not have been the hi-fi,...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=FW-M777/22&scy=GB&slg=AEN&grp=HOME_ENTERTAINMENT_GR&cat=AUDIO_SYSTEMS_CA&sct=MINI_SYSTEMS_SU(JUST COPY & PASTE THIS INTO YOUR BROWSER)THIS WILL GIVE YOU A GOOD STARTING POINT.THANX FOR USING FIX YA,PLEASE RATE ALL REPLYS
TRV#!* Has picture but no sound
If you were watching movie on camera LCD and got No Sound, its possibility of built-in speaker is defective. Please check the sound by connecting camera to TV. If sound comes from TV, it means built-in samll speaker is defective and needs to be replaced.
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
