SOURCE: freezer not keeping foods frozen
If this freezer is running all of the time and only freezing the walls at the top inside it is a good chance there is deteriation in the piping in the walls eg (rusty pipes) letting the refridgerant escape (common fault) with chest freezers.If it is more than 7 years old it would be advisable to replace it as the repair would probably cost 3 quarters of replacement price.Hope this helps. Kind Regards.
1.
The first thing you must know is that your refrigerator should be
set at 37-38 degrees. Anything at 40 or higher and you are risking
food born illness (food poisoning) or spoiling your food. Place your
magnetic thermometer in the refrigerator.
2.
Set your dial on your refrigerator to the second lowest setting. (If
your refrigerator is already equipped with a digital thermostat,
simply set it for 37 or 38 degrees and do not move on to the next
step)
3.
After 2 hours, check your thermometer reading. If your reading is 38
degrees, there is no need to go higher and you are ready to put your
groceries in. Be sure not to open and close your refrigerator during
these two hours or your temperature reading will be incorrect.
4.
If your reading is higher than 38 degrees, move your dial up to the
next coldest setting and repeat the steps every two hours until you
reach the correct temperature for your refrigerator.
5.
Once you have reached the correct refrigeration temperature for your
refrigerator, place the magnetic thermometer in the refrigerator
permanently and watch for changes.
Typically, your
refrigerator temperature will need to be adjusted with the seasons,
a higher setting in the summer and a lower setting in the winter.
