SOURCE: filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
SOURCE: where can i find parts for a regalware k1355 55
I have a Regalware 55 cup coffee urn, model #K1355. I do not have a part's list for unit. The part I'm looking for is a small switch. It says WR-I think that stands for White Rodgers. It's a four terminal switch two terminals on each side. The numbers on switch are161491 085n, other numbers on switch are250c, 158E,andTf318c. can you help me find this switch.
SOURCE: My KF 180, Type 3115 Braun Coffee Maker stopped
I have the same problem and even though I was able to disassemble the unit + get to the heating element, I fear I won't ever find a replacement part. Element is def bad; checked w/ohm meter across element - OPEN.
Like everything else we buy, coffee makers are throwaways when they fail so no one sells repair parts.
SAD!
