You will need to take the negative cable back off and leave off while you are cleaning the throttle body.take the hose off going from air box to intake and take some carb or throttle body cleaner and spray on a rag and then open the flap on inside of throttle body and clean all of the build up out from around the flap.once you have it clean put the cable on and take it for a drive to let the computer relearn its value of the throttle position angle. i hope that this will help and let me know if i can help you any further........good luck let me know if you got it fixed cause this should take care of it it is a common problem.........
