Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 4 cycle gasoline trimmer model tb 425cs. I was cutting rather high grass, and it kept tangling around the curver shaft until the whole string assemble broke apar I believe I need all the parts from the cutting shield to the cutting attachment
Kelly
Level 3:
  • Master 3,740 Answers
  • Posted on Jun 06, 2011
Kelly
Master
Level 3:
Answers
3740
Questions
Helped
2161943
Points
12091
Hi and welcome to FixYa, I am Kelly.
You can find your trimmer here:
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Grass-trimmer-weed-wacker-Parts/Model-TB425CS/1307/1503820?pathTaken=&prst=0&shdMod=TB425CS
You can click on Boom and trimmer parts to see the details.
Or you can use this direct link:
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Grass-trimmer-weed-wacker-Parts/Model-TB425CS/1307/1503820/P0403525/00002?blt=06&prst=0&shdMod=TB425CS
For a printable enlarged picture use this link:
http://c.searspartsdirect.com/lis_png/PLDM/P0403525-00002.png Use IE explorer to enlarge it to 200 % for best viewing.
Hopefully this is what you needed. If not respond here and I will help you.
Thanks for choosing FixYa,
Kelly
4helpful
2answers
Troy bilt troubleshooting
Bushing is worn out. You will need to replace the shaft. Fairly inexpensive.
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Troy Bilt TB575EC cutting head hard to load, now doesn't spin.
Remove the cutting head spool and see if you have old grass stuck around the shaft area that could be causing to cease your shaft..
I own a Troy-Bilt 425cs string trimmer with multiple add-on attachments. The unit works fine for string trimming, brush cutting, and cultivating. However, it will not properly power my edger attachment. ...
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Trimmer starts but hardly rotates when giving it gas.
Check for a tangle of grass or wire just above the string head where it attatches to the shaft. A buildup in that area can interfere with the movement of the head.
The head of the trimmer will not turn. What could be common issues as a result?
Sometimes, strands of long grass wrapped around the shaft above the string head impede movement. On a more serious note, the driveshaft could be broken, or the clutch assembly could have malfunctioned. Disassembly will be required if tangled up grass above the head is NOT the problem.You can get help here to do the disassembly and repairs here, just ask!
Motor spins, shaft does not...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
4helpful
2answers
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 • Garden
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
