Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Radio & horn 04 Road Glide
I put new handlebars on my 04 Road Glide and a friend did the dis & reconnect of the wiring. everything looks ok, but now my radio & horn don't work. Are the horn and radio on the same circuit, is there a fuse and where would I find it.
Thanks
Jonn
    Genius:
  • 2,028 Answers
Generally these aren't on the same circuit. There is an inline fuse for the radio, it's located in the power wire for the radio. The horn shouldn't have a fuse, so I'm going to say check the button on the controls.
Posted on Aug 19, 2008
6ya staff
SOURCE:
With the key off and key fob next to the bike when i hook the battery up the horn stays on constantly and the abs module sounds like its spooling. also headlight comes on. What could this be???
Hi, David you may have pinched some wires installing the handlebar control housings for this scenario you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $9 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
How to Install Handlebars on 2015 Harley Street Glide
Harley Davidson DYNA Models Workshop Service Repair Manual 2012
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
How 6ya Works 6ya A must have !!! Totally "FREE"
Nov 27, 2016 | 2012 Harley Davidson Dyna Glide Street Bob
I recently repositioned my handlebars on my 2008 HD Street Glide and when I put everything back together, my starter will not engage now. Somebody please HELP !
What did you do to reposition the handlebars, did you take the right side perch and switch housing apart or off. If so you may have pinched or otherwise damaged the wires or you may have damaged the run/stop switch or the start switch. If you had other wires apart or exposed check them for pinching or other damage as well. If you do not hear the starter relay click you have damaged something in the wiring before it and likley it is in the switch housing or the handlebars themselves.
Jun 09, 2014 | 2008 Harley Davidson FLHX Street Glide
I have a 2007 Harley street glide battery died. I replaced it then the radio would not work. checked the fuses and found all ok. I road it for one day and let it sit for 2 days and the new battery is dead....
May sound like a dumb question bur are you sure you reconnected the wires correctly? If so there could be a short. If the fuses are good I would say between the fuse and the battery. I am not as familiar with the baggers but I know battery quick battery drains on any of my bikes were always a short to ground
Sep 30, 2013 | 2007 Harley Davidson FLHX Street Glide
2006 hd road glide horn not working
Hi Anonymous, first check the wire connections to the horn making sure they are clean and tight, there is power going to it and the ground wire is securely fastened. Then look behind the horn body for a small set screw sometimes with a jam nut. This screw puts tension on the horn diaphram to vibrate alot or vibrate a little. Have someone hold in the horn button while you adjust the screw in or out as necessary. Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 31, 2012 | 2006 Harley Davidson FLTRI Road Glide
Brake lights,turn signal and horn not working...
Check the wiring within the headlight shell--look for connectors that may be corroded or pulled loose. A little WD-40 will favor connection integrity when sprayed into the connectors, then coupling and uncoupling them several times. Hope this helps!
May 24, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Replace battery on my dyna super glide but it won't even act like it is going to start. Everything lights up horn honks but nothing when I hit the starter. Doe it have something to do with the security...
Bypass the starter switch with heavy wire. Go from positive battery terminal to starter post to see if starter is OK, if it is check wiring. Make sure key in ON position to test, bike in Neutral. You'll know right away if starter is OK. More than likely it is the starter switch button on the handlebar. I don't know anything about the security systems, but lets' hope it is not that.
May 15, 2010 | 2002 Harley Davidson FXD Dyna Super Glide
Started bike hear a noise now right speaker on my 04 road glide doen't work. Looking for help
Pull the faring, check for loose wires on the speaker. This is a common problem.
Jul 15, 2009 | Harley Davidson 426290 AM/FM Radio
Lands Phones Logo
238 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
