You posted next to a photo showing hydrofarm analog timer with segments located on dial face.
Open following link for general look at setting analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Analog timers have a minimum set time of 15 minutes because the trippers-or-pins-or-segments are made certain width.
If you want 1 minute ON and 5 minutes OFF, you need digital timer.
Most digital timers have minimum set time of 1 minute.
But digital timers have limited number of set points per day unless you get into heavy-duty Intermatic timer like the ET70115 timer with 100 or so set points.
If you want 1 minute on and then 5 minutes off, and want to repeat that same cycle over and over throughout the day and night, you would need 240 set points.
Or check out 120V adjustable cycle timers.
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
If you want the cycle timer to operate certain hours only, then put ordinary 24-hour timer between the cycle timer and the load.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
