Posted on Jun 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have replaced the toner cartridge in the canon image runner 3025 and it still says i need to replace the toner. I tried another toner cartridge but it still is not registering
Marius Chiriac
Level 2:
  • Office Equip... Expert 242 Answers
  • Posted on Jun 06, 2011
Marius Chiriac
Level 2:
Answers
242
Questions
0
Helped
114240
Points
658
try to do this, enter in service mode and in the copier menu find function and in this menu find install toner or TNRINST and hit the OK key.
Entering the service menu is easy:
press service key them 2 then 8 then service key then navigate the menu copier>function>install toner
Can someone show me image of originally toner of ir2318 please
Toner cartridges for Canon IR 2318 L - compatible, original
https://www.drtusz.com > ... > Canon image RUNNER
Category, Laser Cartridges, Availability, Available in 24h. Type, Compatible, In stock, 124 szt. Class, Toner, Weight, 430 g. Color, Black, Yield, 8500 pages.
Buy Canon imageRUNNER 2318 Toner Cartridges from £31.74
https://www.cartridgesave.co.uk > Canon > IR-2318
Toner for Canon IR-2318 printer. Huge range of Canon toner cartridges. Free delivery & award winning customer service at Cartridge Save.
Toner cartridge for Canon IR 2318 / L - Compredia.eu
https://www.compredia.eu > Canon > Canon IR Series
Toner for Canon IR 2318 / L: 0384B002, CEXV14, 0384B006.
Laser Toner cartridge Canon IR 2318 [Canon IR ... - AGAWA.PL
https://www.agawa-shop.com > ... > Canon IR 2318
AGAWA.PL - Inks and Cartridges for Canon IR 2318 printers. In offer remanufactured cartridges, original products and inks for cartridge reffilling.
Canon NPG-28 Toner for iR2420/iR2318/iR2018/iR2422 ...
https://www.amazon.in > Canon-NPG-28-iR2420-iR231...
Canon NPG-28 Toner for iR2420/iR2318/iR2018/iR2422(Black) Rating: 3.6 · ‎23 reviews
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Scanning using canon image runner 3025N
Hi Swandi,
Have you installed the scanner utility software before?. If yes, you can use the software or uses other application such as photoshop :)
Have a nice day!
Printer Clinic
HOW TO LOAD STAPLES IN A CANON IMAGE RUNNER 3025
pull the finisher assembly out by the handle located just below the finisher output tray.on the back side of the finisher u will find the stapler unit.reload them by simply taking it out and then close the finisher
We need to replaced our toner at cannon image runner 5020?
just open the cover on the rigth side near the control panel display then install the toner cartridge
3helpful
2answers
Canon ir 3025 service error
Pls. tell wich sevice error, eg. E019, E007,...
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
Color toner
try this on the screen you touch system moniter then consumables this should gine you a divided screen on top toner levels on bottom should say change each toner select the ones you want to change
k24674
ADMIN Andrew
ADMIN Andrew
