Cell Phones Logo
A
Anonymous Posted on Jun 05, 2011
I cannot pair a Nokia 6700 with Samsung Galaxy s11 via Bluetooth. The Galaxy recognises the Nokia, but says problem with PIN nunber or Password. I don't know of any such PIN or Password. Cannot connect !
Anonymous
Level 2:
  • Expert 243 Answers
  • Posted on Jun 05, 2011
Anonymous
Expert
Level 2:
Answers
243
Questions
0
Helped
49017
Points
867
If you need the pairing code for Bluetooth to connect just pairing with the same code in each device
for example if your device asking for code just enter 1 in your device ( Samsung galaxy) and enter the same code (it means 1 for Nokia), the code will depend on you but the important the code must be same each other.
  • debdeb45 Aug 06, 2011
    I won the samsung Galaxy S11 . Do you have any idea how I can get the code to unlock it as i am with another cell phone company on a 3 year contract so i want to put my sim card in it to use it can you help when i put it in it said unregistered sim card
How to Bluetooth pair a 65"seiki smart tv model# se65upc4t to a Android phone.
go into your android phone and go into bluetooth and go into bluetooth settings on your smart tv know the bluetooth name in your smart tv,check it on your android and pair both
Pairing my samsung galaxy grand prime phone with my 2014 honda cr-v vehicle
the password or pin is likely the password or pin to open the phone.
How can I change the pin or password on the hmdx rave speaker
go into your settings of phone a see if its saved an delete it then pair again.
How do I enter the pin code for my bluetoothit says pincode incorrect for my Samsung Galaxy II
The pin code is likely to be one of the following unless otherwise noted in the manual.
1234, 0000, 1111.
I would be able to help more if you note the model of bluetooth device you are trying to setup. Model number should be on the bottom or back the device.
20helpful
2answers
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
I have two bluetooth enabled phones that I would like to get paired. The first one is a Samsung Galaxy Tab and the other is Nokia 2630. I would like to use the SGT's A2DP / Call and have the Nokia on...
Sure! If your headset has never been paired to another device before, just by turning it on, it should enter the pairing mode, denoted by its indicator light steadily lit in blue. Otherwise, starting with it turned off, press and hold the answer/end key some seconds beyond the point to turn it on. Release the key only when you notice the indicator light steadily lit in blue. Now, first on your Galaxy Tab, go to 'Menu > Settings > Wireless & network > Bluetooth settings' and tick the 'Bluetooth' checkbox to turn it on. Then, tap 'Scan devices'. After a little while, your headset should appear in the list of paired devices. If needed, slide your finger to find your headset in that list. Tap it to start the pairing process. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You will be prompted to choose the bluetooth services you want, i.e. phone and media. Of course you can come back to these settings whenever you want, in order to activate or deactive these services. Now untick the 'Bluetooth' checkbox to turn it off, in order to pair your headset with your Nokia phone.
Then, turn your headset off and press and hold the answer/end button to put it in paring mode again. Now, on your Nokia, go to 'Menu > Settings > Connectivity > Bluetooth' and select 'Bluetooth > On'. Then, select 'Search for audio enhancements'. After a while, your headset should appear. Select it and make it connect. Again, if a pairing code (or PIN, or passkey) is requested, enter '0000' (four zenros).
Your headset will be able to handle both your Galaxy tab and your Nokia phone at the same time. it is already connected to your Nokia phone. Go back to your Galaxy tab, and tick the 'Bluetooth' checkbox again to turn it on. You should see the bluetooth icon light in blue in the notification area.
By the way, your headset's user guide can be found here, your Galaxy Tab's here, and your Nokia phone's here.
Hope you are able to sort your problems out soon.]
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Cant setup audio from samsung galaxy to toyota camry xle 2010 via bluetooth tohear music.Bluetooh works for phonecalls though.
Most likely due to the pairing problem. The technology which allows streaming is called A2DP and some times during the pairing the other device (your car or other) might not be able to respond or configure itself. I can suggest few steps,
1. Make sure both devices support a2dp (Samsung Galaxy S does support and your camry XLE too supports)
2. Restart the phone/Car bluetooth
3. Unpair and try to do pairing one more time. If it asks for any password then provide the default password as per your car manual
4. Try to make the phone visible (Applications>Settings>Wireless and Network>Bluetooth Settings>Visible.
If all options fail, perhaps you may check with the toyoto service center. Sometimes the other device may need specific security parameters or requirements.
Hope it helps.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
