Tip & How-To about Computers & Internet
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
Computers & Internet Logo
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
I'm using NComputing X300 kit to connect sets of PC's running Windows XP SP2. I install windows 7 on the PC's and the NConputing is not supported any more. Can you help me to get the X300 drivers to work with the windows 7?
Hi enoonoo
Even though the product claims to be compatible with Windows and Linux, it has 1/ no drivers for any Linux system and 2/ does not work with Vista / Windows 7 .
It is useless , it will just don't work anymore .
You can always create a network , sharing all machines via a gateway . It also works between different OS versions like sharing a W7 unit with an XP one .
Best regards ,
fanaudi .
i bought a dell desktop with windows 7 installed. but i now want to install windows xp on that computer. but when i insert the xp cd and select install windows xp option i get an message somewhat like this This program is blocked due to compatibility issues Setup cannot continue because the version of windows on your computer is newer than the version on cd what do i do ???
I believe the only way would be to remove Windows 7 from the computer. If the hard drive with windows 7 on has any programs and files you would loose them during the proccess. If you want to run programs that are not compatible with Windows 7, I think you'll be able to tell the computer to run it as XP, or I should contact Microsoft if you have problems with Windows 7 and other programs. You should look at all the avenues before deleting Windows 7 though.
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with Windows 7 even though the box says XP and Vista. I have tried 4 times. Any solutions?
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Grand Canyon Tech
Grand Canyon Tech
