Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers if your computer came with a motherboard disc the drivers could be on it or you could download cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need http://download.cnet.com/%7Bvalue=http://www.download.com/ati-catalyst-display-driver/3000-2108_4-10608736.html This release for all Radeon family products updates the AMD display driver to the latest version. This unified driver has been further enhanced to provide the highest level of power, performance, and reliability. http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question or exclamation mark ! ? or red x right click to re-install drivers
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope one of these helps
SOURCE: i need a sound driver for my daughter's computer
Visit the Intel.com and go to the products, look for the motherboard section of the website. Once you found your motherboard model, click it and find driver downloads. If you are not sure about your motherboard model, just download this Id Tool: http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=17730
SOURCE: sound driver of intel E210882 motherboard
The Intel D865GVHZ (Also Known As : E210882) Socket 478 865GV Chipset 800MHz FSB (HT/PRESCOTT) w/VIDEO/SOUND/LAN
Here is the Download location for Every Driver for that Motherboard for All OS's.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1704&OSFullName=All+Operating+Systems&lang=eng&strOSs=All&submit=Go%21
That should fix yah. Have a good one.
SOURCE: Good Afternoon Sir.!!
Intel has an auto detect and download drivers tool here: http://www.intel.com/p/en_US/support/detect/ which you could try.
If that doesn't work you can also follow the intructions here http://devid.info/en/page/device/
It should hopefully give you a driver for your device.
Thanks
SOURCE: Intel E210882 Motherboard can't ON
> Check the power connection to your computer in good condition.
> Remove the SW on the motherboard connection and switch on the computer by using the SW pin tespen to affect positively and negatively. (To make sure the button on / off function)
If your computer can be turned on this means that the button on / off there is a problem but if the contrary, create a test on your computer power supply box in a manner which was troubleshooting with the power supply box which is still functioning properly or even better one.(Problems on the motherboard can also cause your computer can not be turned on)
If you have to do some tests and the problem is not coming from your motherboard, I believe there is no problem for your computer is switched on and used as usual.
