Cars & Trucks Logo
A
Anonymous Posted on Jun 05, 2011
I have a 2000 chevy silverado and when in Drive going up a hill it seems like the transmission can't down shift or doesn't know what to do, I step on the gas and the rpm's don't go up and there is a fluttering sound and i loose speed. I manually put the shifter in 3 and it works fine. Its to the point where i have to manually shift through the gears, Is it the solenoid for overdrive ?
Jonah Oneal
Level 3:
  • Chevrolet Master 14,092 Answers
  • Posted on Jun 05, 2011
Jonah Oneal
Chevrolet Master
Level 3:
Answers
14092
Questions
0
Helped
7239997
Points
44533
TRANSMISSION SLIPPING NOT ENOUGH FLUID IN TRANSMISSION OR NEED A TRANSMISSION FLUID FILTER CHANGE.IF YOU HAVE PROBLEM WITH OVER DRIVE.CHECK ENGINE LIGHT WILL FLASH ON WARN YOU PROBLEMS WITH TORQUE CONVERTER OR 3 - 4 SHIFT VALVES SOLENOIDS.
2answers
My 2000 chevy silverado will not go in reverse but it will go in drive and stay in first gear
best prices on transmission repair kit, or new transmission here>>www.discountbargainprices.com
Car doesn't kick down gear going up hills
A/T
The modern A/T has 4shift methods.
Foot (passing) called detent TV kick down cable.
the shift lever.
the Vacuum modulator (load, = hills)
and tail shaft RPM (speed)
so seems like the MOD on the A/T is bad.
2answers
2answers
2000 sunfire not shifting right
will it shift left ?
replace or check the TPS on the throttle body
see if that helps
1helpful
Hi I'm an owner of a 1998 Honda Oddysey. I would like know the mechanics of using its automatic gear transmissions and specific function. For example when do I use D3 or D2 etc... And how do I shift...
Gear usage.
The Drive is for normal driving.
D2 is for hill/steep climbing drive.
D3 is for hill/steep going down drive.
If you have overdrive button, use it when you exceed 60mph.
That's all you have to do when you see roads that is going up nor down.
Thaks for asking FixYa!
8helpful
3answers
Transmission shifts hard into second gear(auto trans). However, when shutting engine off and restarting, the hard shift will go away. It will come back in a few days. Doesn't seem to matter how many...
it may be a bad tps ( throttle position sensor ). it causes transmission shift issues, bucking,jerking, idle surging, engine cut off, surge while crusing down highway. if this does not solve problem, it may be a sticking valve body in transmission. have a good day !! for an automatic tranny.
Transmission shifts hard when slowing down to stop
Dirty trans filter,stickey trans solinoid,or your torque converter is not unlocking.If you can due it yourself try running some trans flush then replace the filter.
1helpful
4answers
2001 chevy silverado 1500 AT shifting problems
is your tow/haul button pushed? is the tow/haul light burned out? i would ask myself these questions
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
