SOURCE: Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
SOURCE: rca p61939
You will have to remove the small control panel printed circuit board from the front of your unit & inspect it for cracks on the board or bad tact switch/s.
SOURCE: OSD function menu
ok i think i know how to get rid of it now, i did an ATX reset on it and it does go away HOWEVER as soon as you push the menu button again it comes back.
ATX Reset: unplug the main power lead then hold down the power button on the front of the monitor for about 10 seconds, plug the mains lead back in and then switch the monitor on.
SOURCE: 720p output doesn't work
The problem might be that the set can not handle the change in signal. Try setting the AVR-247 to 720P first then turning on the set. Or manually set the TV to receive 720P then change the AVR. TI believe that you have a connectivity issue where the two units are not speaking the same language at the same time. Update this with your results and please post the TV make and model.
Thanks,
Dan
SOURCE: Rotel Receiver RSX-1067
the rotal reciver is on the way out to the bin ,,,i chucked mine out and got a new one and was all good again i had same problems thats all i have to say and i dont think there is a fix to that
