SOURCE: Hotpoint Ultima W860
hi there f10 fault code means pressure switch not sensing,
this could be to do with low water pressure or a bad connection on the pressure switch or control module which is located at the back left hand corner of the machine, remove backplate to gain access and remake all connections on module, if this should not resolve the fault i would be looking to replace the pressure first part no= C00112659 cost about £15
ps. always disconnect from mains before carrying out any work
SOURCE: Hotpoint Ultima Wt761 is displaying F-08 what can
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
SOURCE: my Hotpoint Ultima keeps displaying an F10 fault
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
